Question about True T-49 Side by Side Refrigerator Commercial
Not cooling Just took over a business. 2 True cooler and a freezer there. Not used in 2 years. All work but one. Fans and motor work, just won't cool at all. Could it be just freon. Probably less than 10 years old. If freon, is it a do it yourself for a novice. Thanks
  • 943 Answers
Thanks for the question no not a job for you you need gages and knowledge of operating presures let a service tech do this thanks the appliance doc
Posted on Sep 16, 2008
True gdm35 evaporator fans not working?
change the fan motor, if the fan dont wonrk wont spread cool air
Sep 18, 2014 | True Display Refrigeration GDM-35F
My Akasa laptop cooling fan has become noisy after a good few years of use. where can i get it serviced
sounds like the bearings are bad in the motors. It would be cheaper to replace unit than fixing it. new fans/motors would cost more.
Aug 05, 2012 | Akasa AK-NBC-01B Notebook cooler Black
I have a True GDM10 that won't cool. Motor runs normal, Evap fan is running, no ice build up, just won't cool. Is this a coolant problem and can a True GDM10 be recharged? See no hook ups in t
First let me ask, are you sure the compressor is running? If you verified that it was running by vibrations in the compressor area just know that the condenser fan can also cause those if your machine has one. The way to tell is if the compressor is generating heat. With that said, assuming that the compressor is running, and all applicable fans are running, you need to determine if the machine was losing cool over time or did it happen overnight? If the latter of the two you'll need to isolate where the leak is, be it the evaporator or the compressor area. To actually add freon to the system if no access ports are available you;ll need to get a piercing valve, I personally use pt# bpv-31 bullet piercing valves.
Jun 15, 2012 | True GDM-10 Refrigerator
Delay on evap. fan sistm.404a
Give the evaporator a chance to get cold, then check you've got power to the fan, via the evaporator thermistor and door switch
May 02, 2012 | True Freezers
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
I have a True Cooler GDM-35SL-RF. the fans are not working but the compressor is. What can I do to fix this and where on the cooler would I find the problem?
They have a support line here:
http://www.truemfg.com/24HourTech_en.aspx?language_id=1&event_id=401&from=food
Our Technical Service department is available via Internet or phone
Monday - Friday 7:30 AM - 5:30 PM CST and on Saturday 8:00 AM - 12:00 PM CST.
Via phone please call 1-800-325-6152 and ask for the Service Department
You can also use the page to ask any questions. I suspect you have a fan relay that has failed as the fans should be running anytime the compressor is running. Since all of the fans are not running that leads me to think it is a relay problem.
One thing to need to make sure is to verify that all fans.. condenser (bottom of the unit) and evaporator (inside the unit) fans are not running. If the condenser fan bottom of the unit is running and the evaportar fans are not running it could be something as simple as a door switch that has failed. Call them during business hours and I am sure they will tell you what the remedy is.... and of course.. do their very best to ensure they get to send a repair tech your way.
Thanks for choosing FixYa,
Kelly
Sep 04, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
Ererteqrt
True cooler. Where do you buy and how do you replace refrigerant. Motor and fans working. Do you need a professional or can a layman do it? Took over business with great equipment but no owners manuals.
Aug 10, 2008 | Refrigerators
Hamilton beach water cooler is not cooling
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside the motor and several revolutions later might get some relief until a new motor is installed.
Jun 07, 2008 | Hamilton Beach Water Cooler with Storage...
True T-49 Side by Side Refrigerator Commercial Logo
142 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
