Question about Dell 1700n Laser Printer
Load/Remove Paper Light Flashing
Computer won't print in some applications because it doesn't recognize there is paper in the printer.
  • killer kurt Jan 06, 2009
    I have the same problem, I have done some inspection and when I try to print the feed rollers that pick up the paper and feed the paper from the tray into the printer itself are not lowering, they just sit there. I tried turning off then back on the printer but to no success. One time it worked after pulling the tray out then jigeling the arm but one worked once.
IF THE ROLLERS DON'T TURN AND MAYBE YOU HEAR A CLICKING NOISE FROM THE LEFT SIDE OF THE PRINTER, THERE IS A SPRING CLUTCH INSIDE THE GEAR AT THE END OF THE SHAFT GOING TO THE SWING ARM. I FOUND THAT SOMETIMES GREASE GETS INSIDE AND CAUSES THE SPRING TO SLIP INSTEAD OF GRIP LIKE IT SHOULD. IF YOU'RE VERY CAREFUL, YOU CAN TAKE OFF THE LEFT SIDE COVER AND LAY THE PRINTER ON ITS RIGHT SIDE (LEFT SIDE FACING UP). THEN REMOVE 3 OR 4 SCREWS AROUND THE GEAR ASSEMBLY AND LIFT THE ASSEMBLY STRAIGHT OFF THE PRINTER. TO GET TO THE SPRING CLUTCH, YOU'LL HAVE TO MOVE A COUPLE GEARS OUT OF THE WAY (REMEMBER HOW THEY GO BACK OR YOU'RE SCREWED - AND WATCH THE TONER ARM SPRING AS WELL). REMOVE THE PLASTIC C-CLIP ON THE END OF THE PICKUP SHAFT AND LIFT OFF THE CLUTCH GEAR. PULL THE GEAR APART AND WIPE OFF ANY GREASE FROM THE INNER SURFACES WHERE THE CLUTCH SPRING SITS. REVERSE YOUR STEPS TO PUT IT BACK TOGETHER.
--SORRY, MY CAPS LOCK DOESN"T WORK AND I DON'T FEEL LIKE HOLDING DOWN THE SHIFT KEY TO TYPE ALL DAY.
Posted on Jan 06, 2009
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Paper light flashing when paper tray is full
Paper got stuck in my HL2030 printer I cleared it but red light keeps flashing and won t let me print.
Feb 17, 2011 | Brother HL-2030 Laser Printer
Deskjet 895Cx1 Green and Ornage lights flashing together Problem & solution, please
Please find below the section in the user manual for the printer that tells you what the lights mean. Hope this helps.
Sometimes the lights on the printer signal a problem:
Both lights are off
• The printer is turned off. Press the power button. If you still don’t see the glowing green light, make sure the printer is plugged into a power outlet and that the outlet has power.
Both lights blink
• Paper may be jammed in the printer. Open the front cover and remove any jammed paper. Close the front cover and turn the printer off, then on again. Go to “Clearing a Paper Jam” on page 67.
• The cartridge cradle may be jammed.
Close the front cover, turn the printer off, then on again.
The power light blinks, and the resume light is off
• This is normal behavior when the printer is receiving data, printing, or waiting for ink to dry.
The power light glows steadily, and the resume light blinks
One or both of the inkjet printer cartridges may not be seated properly, or you may have forgotten to remove
the tape from a new inkjet printer cartridge. Open the front cover. Remove both inkjet printer cartridges. Holding the black plastic sides of the inkjet printer cartridge, check to be sure the tape has been removed from the print head. Then replace the inkjet printer
cartridges in the cartridge cradle. Make sure each inkjet printer cartridge is pressed all the way into the cartridge
cradle. If an inkjet printer cartridge feels at all loose, it is not properly seated. For instructions, go to “Insert Print Cartridges” on page 5.
• The front cover may be open. Make sure it is closed.
• There may be no paper in the lower paper tray. Load paper.
• The printer may need to reset. Press and release the Resume button.
• Your computer may be low on memory. Try restarting it.
• Turn the printer off, then on again. (This resets the printer.)
• Repeat the printing process.
Sometimes problems disappear when you try to print your document again.
• Printing problems can often be caused by errors in your applications.
If you can print from the SimpleText or TeachText application but not from another application, it’s probably a problem with that application. Contact the publisher of that application for help.
• Restart your computer.
Nov 22, 2009 | Apple HP DeskJet 895cxi InkJet Printer
Canon Mx300 wont recognize my paper. says:load paper
I cant print...orange light under alarm keeps flashing...please help...patricia
Jun 04, 2009 | Canon MX300 Office All-In-One Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
Paper jam
I removed paper from jam, red light will not quit flashing, I turned
printer off and on again, but it will not print and red light will not
quit flashing, What can I do?
May 12, 2008 | Office Equipment & Supplies
Dell 1700n Laser Printer Logo
298 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
