Question about JVC SR-DVM700 DVD Recorder/HDD Recorder
Dubbing hdd to dvd
Machine refuse to record on any disc i use includeing jvc discs. I have carefuly check the dvd specs and am sure they should work. Machine has sucessfully worked in the past. Any suggestions
  • abdennebiomr Sep 22, 2008
    ma machine refuse de lire et d'enregistrer sur toute sorte de dvd elle ecrit toujours sur l'ecran "disque illisible verifiez le disque"
  • redspty Jan 17, 2009
    I cannot dubb from the hdd to DVD, It can't do it in High Speed the machine tell me the exact running time of the title, but when is in progress sometimes abort the operation after few minutes, check the disc and the machine tell me cannot read the disc, see the back on the disc and see only a very little portion used, but I can't use that DVD-R again. It's brand new and it never has done the dubbing to DVD. I edited the track in the HDD before dubbing.
I had the same problem I thought it was me!! Dooh but sent it back and JVC very kindly replaced the DVD unit, I believe free of Charge and after is was out of warranty by a few months.
Well done JVC on this one.
Posted on Sep 07, 2008
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
JVC SR-DVM600 Dubbing from HDD to DVD Problem
Have you tried using a different brand disc. When I first purchased my DVM-600 it would not record on Memorex discs. I purchased TDK -R discs and all is fine. In the old-school analog world, all specific format tapes were computable to all machines. In other words, a VHS tape recorded in your VHS recorder will play back in my machine and every other VHS machine. Because the DVD format has so many formats and standards, compatability issues are quite common.
May 07, 2009 | JVC SR-DVM600
Will not dub to dvd-r from HDD in high speed mode
It will only high speed dub in the speed it was recorded in. You can dub, for example, SP on your hard drive to SP on a DVD. You cannot dub high speed, for example, SP on your hard drive to LP on a DVD.
Dec 01, 2008 | Panasonic DMR-EH50 DVD Recorder
I have a hdd/dvd recorder model rh7880/rh7500 set timer recording to record onto dvd, machine switched itself on as normal but did not start to record and froze up.cannot get anything to respond either...
Recorder wasn't under warranty, so opened the unit up removed the dvd - rw disc ,which was corrupted as it turns out, put the machine back together switched it on and it worked perfectly.I have since tested it by recording both on to dvd,hdd and used the dubbing format and have had no problems.In the future I would recommend bying only top quality discs as it seems a dodgy one was responsible.
Jun 29, 2008 | LG Televison & Video
Dubbing from HDD to DVD disc
I beleive you can only dub from hdd to disk,
Try formatting the disk first.
good luck
Apr 03, 2008 | LG RH177 DVD Recorder/HDD Recorder
This is a disc read problem the discs recommended in the manual seem to be the only discs that will work on this machine.
I was getting the same error code everytime but the disc that i know does work is a Verbatim 16X DVD-R.
These discs work in all situations on my machine , dubbing and direct from TV.
Mar 22, 2008 | Televison & Video
Dr-mh30s. stops dubbing after a few minutes.
I seem to have sorted this problem for me simply by unplugging power.
I actually left it for nearly a week before plugging in again, but I'm sure a day would do, probably less.
Dubbed 2 playlists since, no problem.
Nice simple solution if it works.
Feb 22, 2008 | JVC DR-MH30S DVD Recorder
Dubbing to DVD not working
make sure the DVD is formated.
Feb 01, 2008 | JVC SR-DVM70 DVD Recorder
DVD Burning doesn't Disc in Setup..
Been checking out my m/c and found that there are many -r & -rw discs the m/c does not recognise which gives rise to this problem. However the m/c does recognise VERBATIM discs and I have been able to record and dub to them with no problems.
Jan 22, 2008 | LG RH-4820 DVD Recorder
DVD problem
I've had the same problem. Are you using x8 DVD-R? I had no problems with the old x4 discs, but had the (long) Self Check process and a failed dubbing occur between 1/100 and 2/100 in the dubbing process with the x8 discs. I've found two workarounds: 1) The problem doesn't seem to occur if the recordings are made with hi-speed dubbing enabled. I do this now as a default, but the loss of the ws tag is a pain . If I still get a dubbing failure with hi-speed dubbing, a quick power down/power on of the unit seems to rectify the situation. 2) If you record a "leader" in hi-speed dub mode of a minute or two, and dub it onto a x8 DVD-R first, you can then copy non-hi-speed dub recordings onto the disc. Not quite sure why this works, but it does - it's like the first minute or two being dubbed over needs to be hi-speed enabled to be written from the memory of the E-85 to the disc, but once that's done it dubs as it should. btw, another process that crashes the unit is if you try an change the thumbnails on a x8 DVD-R. Not the end of the world but again annoying on expensive equipment less than two years' old. DVD-RAMs are not affected by the problem in my experience. Apparently there's some firmware in the US that addresses the problem with x8 discs - , but Panasonic UK don't distribute it. I think the E-85 is a good box but it has proven too buggy and I'm thinking of upgrading it, possibly when the new 85 is released by Panasonic in a few weeks. Good luck
May 14, 2006 | Panasonic DMR-E85H DVD Recorder
JVC SR-DVM700 DVD Recorder/HDD Recorder Logo
462 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
