Question about Polaroid FLM-323B Television
Forgot v-chip code
NEED TO RESET TV V-CHIP CODE Forgot the code to unlock the v-chip. I've called the Polaroid Helpline and we tried to reset it back by using the manufactures code "0000" and reseting the programs back to what they are at the factory, but no luck.
Does anyone know how I can reset and unknown V-Chip Code?
  • Heibult Aug 08, 2008
    Need to reset an unknow V-Chip Code for Polaroid HDTV FLM-323B. I've tried calling the helpline and reseting it back to the manufactures settings, but no luck.
  • 5 Answers
SOURCE: ILO 42" plasma V chip block pasword/code
Try these codes 8202 or 8205.
Posted on May 10, 2008
SOURCE: Unknown chip
sound driver
Posted on Aug 13, 2008
  • 73 Answers
SOURCE: what is the v-chip code for polaroid tv
Parental
DVD discs equipped with the child lock function are rated according to their contents and settings vary from disc to disc. Depending on the disc, you can lock out selected scenes or playback of the disc altogether. Access parental control by pressing the left/right (direction buttons together) on the remote control and then press the OK button.
System Setup/Password
Parental control features are password protected. The original setting is unlocked. This setting allows you to use number buttons to input any password. Note: The Default Password is 1369. This password is always effective even after you
have selected your own password and changed it. To avoid the possibility of others using the default password to set the parental level and change the password, you can record this default password in another area and delete it from this manual. Some discs can be limited depending on the age of users while some discs cannot.
Manual is here
http://www.polaroid.com/service/userguides/ce/under_cabinet_lcd_tvs/fdm0700a_ug.pdf
(you need Adobe Reader) and their phone # is
at the end!
Posted on Jan 05, 2009
  • 59 Answers
SOURCE: HP DV6000 PROBLEM WITH VGA CHIP
Since this is an on board video chip you can't change it out or get a new grapics card. The HP DV6000 doesn't have a graphics card adapter in it. So your best bet would be to replace the motherboard.
Which you can search for online to buy.
Hope this helps.
Posted on Mar 02, 2009
SOURCE: Changing the cutting blades on a mantis Chip Mate
The Mantis Chip Mate was actually made by a Swiss company called Stoeckler, under the model name Bio-Shredder LGM-600. Neither Mantis nor Stoeckler seem to have service parts or info on these models. Given the blade material the edge did last long and would dull out quickly on hardwood material - best to attack only pencil diameter material or soft material. The manual is of limited use but boiled down you have the following info:
STEP 1 UNPLUG IT! (Seems silly to say but just in case someone of less mechanical inclination reads this.......) Also being made in Europe, all the fasteners are Metric, not SAE/Inch.
The motor/drum assembly must be removed from the chute housing to get to the blades (7 - 5mm allen head bolts holds the drum inside the chute housing). A "T" handle hex wrench a minimum of 6" long will work to access some of the tigher clearance areas. Use a WIDE Large blade screwdriver the help separate the drum halves if they don't come apart too easily. The drum is the motor so it will stay with the smaller plastic housing part - DO NOT force the drum off the small housing part.
A 10mm open end wrench is needed to turn the bolts into the wedge/blade assembly on the drum (ie. turn the bolt head so it screws IN) to loosen the wedge assembly until the blade and wedge can be removed from the drum.
The blade goes back in the wedge blocks so the the bottom of the blade rests against the wedge and not the drum (ie the sharp edge against the wedge not the drum). Make sure the holes in the blade fit over the bumps in the wedge.
You'll next need to remove the counterknife inside the chute house and make sure the edges therer are sharp (you can flip the part around to use any of the 4 edges and bolt it back in or file them sharp and reinstall into the chute housing, BUT LEAVE IT LOOSE.
You need to adjust this counterknife distance from the drum knives. You'll need a 3.5" wide or so piece of shim stock that is 0.3mm thick. Put the drum/knife assembly back in the chute housing and rotate the drum around until one of the drum knives is under the counterknife. Insert the 0.3mm shim stock between the drum knife and counterknife. Push the counterknife down and tighten the 2 bolts that hold it in the chute. Pull the shim out, rotate the drum to the other drum knife and check for clearance to the counterknife. As long as it rotates by and does not hit you should be ok, but if they are really close, re-adjust the counterknife for 0.3mm clearance to the highest knife. Make sure the gap does not exceed 0.5mm or the unit will not chip/shred properly.
Put everything back together and make sure the bolts are tight!
Should be good to go. Given the blades don't seem to be of any particulary great hardness, I would feed material slow and easy and avoid any hardwood material over 1/2" in diameter. If you need new blades you need to search around to see what can be ground down to fit. Find yourself a person who really knows how to sharpen blades and they should be able to cut something down to fit.
Good luck.
Posted on Apr 26, 2009
RCA V550OT RESET PARENTAL LOCK(forgot code)
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET
Aug 13, 2012 | Televison & Video
Tip
Bypass V-Chip Mitsubishi TV
Bypassing the V-Chip Lock on most Mitsubishi sets:
Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it.
To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV.
To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
on Mar 20, 2010 | Televison & Video
I have a panosoinic tv model CT-2013SA and my son typed in a parental code and forgot it
Hello
There is a way to unlock Panasonic TVs. It will work on most of the Panasonic sets. Just try it.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, that is, switch on the set by its front panel power switch, and put it off by remote hanset, [standby position], then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
OK.
Feb 12, 2011 | Panasonic CT-20G6 20" TV
V-CHIP Problem trying to dissengage
No,way to reset secret codes.Try Mitsubishi wbsite,talk to Mitsubishi customer seviced,might get some diffrent insight.
Jul 24, 2010 | Mitsubishi WS-48313 48" Rear Projection...
How to change the v chip code to a mitsubishi medallion projection tv 62
Good luck, and let us know how you made out with this TV set.
Forgotten v-chip code
Turn the volume down to 0 then change to a blocked channel. (where it asks for v-chip password) Next, on the TV, not from the remote, hold the volume down button, and hold the '0' key on the remote for between 2-10 seconds... the screen should unlock and you should have no V-Chip restrictions.
Mar 10, 2009 | Orion1934 19" TV
V-chip reset
I cannot find any way to reset it. You might contact the manufacturer.
Oct 06, 2008 | Durabrand DWT2704 TV
Forgot v-chip code
Sharp has several locking and V-chip commands but one of these three possibilities should work.
Newer Combos With "Time Limiter" Feature
If the "Secret Number" is forgotten, simultaneously press the STOP, RESET, and VOL up buttons on the front panel of the set.
This disables both the "Channel Lock" and the "Time Limiter" features.
CTV's Lock Mode---Blue screen and display says,Parental Control Rating Unknown
Try This: Hold Channel up and down on the set while pluging in AC cord.
Or Try This: On the set, press volume up and channel down at the same time.
CTV's V-Chip Release
When screen asks you to "input secret number" press and hold channel up and down on the TV set until message disappears. Press menu 2 times to exit.
Hope this helps!
Bill
Nov 13, 2007 | Sharp 25R-S100 25" TV
Unlock code
Bypassing the V-Chip Lock on most Mitsubishi sets: Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it. To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV. To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Good Luck
Mar 28, 2007 | Mitsubishi VS-45609 TV
Polaroid FLM-323B Television Logo
140 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
