Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
DOOR TENSION PROBLEM : DOOR DROPS; NO TENSION AT ALL
  • BrianCA Nov 19, 2008
    My door drops when i open it. There is no tension at all. Anyone have this problem and know how to fix it?
  • bgould Dec 06, 2008
    I have the same problem.  The door immediately drops to the floor with no tension at all.
    It is probably a spring or line problem.
    Can I fix this myself?
    Any secrets to fixing this?
    Thanks
I have had this problem and had to replace the cable (cord) and/or the springs
Posted on Nov 13, 2008
I replaced my door springs but it seams the hinges pop out of the track when opening the door and it causes the door to drop down to far
Tom, I am pretty sure you have not reinstalled door quite right, try again till you get it seated into proper position.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 03, 2016 | Ovens
The door drops all the way down it has no tension / stay open
Hi
Sounds like you have broken door spring/s You will have to turn off the power and pull out the unit and remove the covers. This should entail the replacements of one or both springs.Hope this helps
Robocam
Jul 03, 2011 | Dishwashers
Door drops down no tension
what do you mean buy the door has no tension. looking at the model number it is the two drawer glide systm
Jun 03, 2010 | Fisher and Paykel DS602 Dishwasher
Door sprung?
remove bottom cover. look for an arm at bottom corners. should be two springs attached to give tension. probably got a broken one. drawer rolls out
because door opens farther than it should.
May 21, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Door spring seems to have broken
Yep! What happens is a "T" shaped metal piece that is "screwed" into the spring and serves as an adjustment of tension tears or bends and falls out of the spring(s). Usually one at a time.
If you are clever you can rebend and strengthen this piece and adjust the tension to normal.
Access this by removing the panel below the door where the toe kick is.
The cause of the problem will be obvious and one side will probably still be intact so you can see how they are supposed to be.
May 02, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My KitchenAid dishwashers door will not stay shut. I have replaced both hinges, the plastic rollers for the tension lines that atached to the spring. Still no luck. Could it be that the locking (?) switch...
Sure thing.
Our dishwasher is one that we put our own "Door on it" in our case, it matches the cabinet. It is designed for that.
I went on-line and ordered the replacement parts. I can't recall the site but I will look thru my files and send to you if I find it.
I removed our door front and slid the DW out about 1/2 to 2/3 of the way. I did not want to mess with disconnecting power and water lines. 1/2 way out should be enough room to work on the places you need to be. On both sides near the back and bottom you will see a large tension spring. Be careful not to bust a knuckle here. Using a sturdy hook of some kind is recommended. In place of that you might try a solid wooedn hanger with a heavy hook on it. BE CAREFUL, while pulling on the front part of the spring you will release the tension on the cord that is around the plastic guide wheels and attaches to the bottom hinge of the door.
Release the hook and then the tension you have on the spring. repeat this on the other side. With both sides free the door should lift off the hinges and the base it sits on. inspect your hinges. mine were bent, not much, but I was at whits end. I replaces both. I also replaced both cords that were attached to the tension spring and one of the plastic roller wheels ? I am sure there is a better name for them. It was the longer of that is on the tear drop shaped fastener.
I then placed the door back in posistion and closed it. On the the tear dropped shaped guide wheel (the one at the bottom) you will see that there are holes to adjust the tension. The closer you move this wheel towars the front of the machine, the more tension on the hinges. I set mine in the middle and this seemed to work. Before you slide it back in the space, try a test to see if the door stays shut. ie. run a rinse cycle too. Hopefully that is all you will need to do...BUT.
That was not to total solution in our case. I ended up ordering and replacing the door switch (a black plastic piece that is what the metal latch on the machine is supposed to "hook" into.
Replacing it is fairly simple. I did shut the power off for this. This part is replaced by taking off your face plate which is secured bu screws inside of your DW door around the edge. You will see 4 screws to remove and it "snaps" out. At this point you can see the working relationship with the latch, the switch and the contacts on the switch that the door latch (metal part coming out of the top of the DW) after replacing this...try the process again and hopefully your issue will be solved. I had to remove my latch and bend it back to the original shape and mess around with a slight bend to make it latch and hit the contacts in the door latch.
Good luck! I am sorry this is so long. :-)
Mar 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Oven door won't shut all the way
if it is a drop down door with side hinges, then the chances are it is weak door springs that is the problem.
The only solution is to replace both hinges, as there is normally no adjustment for tensioning.
Hope this helps.
Dec 29, 2009 | Kenmore Ovens
I have a Singer 6233 and the drop in bobbin is too tight. I can't find a screw to loosen the tension a bit.
I went online and found a diagram that showed where the screw was to loosen or tighten the drop in bobbin thread (it faces the front) but it couldn't be seen until I slid the sliding door totally off. I had to use a flashlight and very small screwdriver and was able to loosen the screw a tiny bit and it solved my problem. I've been sewing for over 40 years and didn't know how to adjust the tension on a drop in bobbin until now. You learn something new everyday!
Dec 20, 2009 | Singer Sewing Machines
KEMS378GSS3 Door has lost tension
Please find the diagramatic presentation for the replacement or removal of the door.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/0330c966a25780ac8525740c006f9000/$FILE/4317430.pdf
Do not be worried about the model if its exactly not the same as the basic removal process is 99% similar.
Thank You
May 15, 2009 | Kenmore 63672 Convection/Microwave Oven
I am unable to have the door close fully
Sometimes those springs hang on a hook with "notches" so that you can increase the tension by moving to a higher notch. If they don't have any adjustment on them, and you just put a replacement spring on I'd start looking other places for the problem first. If you got the closest springs they had at the hardware store, then you can increase the tension by curling down (thus shortening) the hook ends of the spring with long nose pliers. On a strong spring like an oven spring this will be kind of difficult.
Make sure there isn't any rubbing or other problem going on with the hinges... sometimes just a couple drops of 3 in 1 oil will do the trick.
Nov 14, 2008 | Jenn-Air JJW8130D Electric Single Oven
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
228 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
