I have a RCA tv and an Onkyo cd/dvd player. I have all run through a Yamaha receiver. I get the error code "unusable signal" when I try to play a dvd. I get the sound, but not the video. What is likely to be my problem? Obviously, I don't have it connected correctly, but I don't know what is wrong.
  • 10,594 Answers
Check A-V cables, most probebly that one is disconneted internaly which goes to TV's Video Input or coming from DVD player's Video Output. Just hook up new cable and try. One more possible thing is wrong set-up or selection in Yamaha.
Posted on Aug 08, 2008
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
I have an Onkyo DR-S2.0 dvd Receiver that will not turn on. That aside I'm trying to find codes for the remote in order for it to learn my Philips tv and my Yamaha stereo receiver. The remote is a RC-437M....
Can't help you with the turning on problem, but the remote doesnt use codes to control other devices it learns the signals from that devices remote. heres a link to the users manual:
http://www.intl.onkyo.com/downloads/manuals/pdf/dr-s2.0_manual_e.pdf
the programing procedure is on page 63
May 21, 2010 | Onkyo RC-549M LCD Remote Control
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
How do I hook up the Onkyo DS-A2X to my Kenwood KR-V5560?
Hook it up just like any basic DVD player. Run the 3-headed RCA connector as follows to your receiver:
Red/White Audio Out to Audio Left and Right of (you choose one unused):
Tape 1 Play
Tape 2 Play
Video 1 Play
Video 2 Play < preferred
Yellow Video Out to: (you choose one unused)
Video 1
Video 2 < preferred
or
Video In on your TV
May 26, 2009 | Kenwood KR-V5580
Connect AV receiver to a Dish receiver model VIP722 DVR
Your DVD player should connect to your TV, not the DISH DVR. Is the Yamaha some sort of receiver or something similar? If so, it should plug into the TV as well. The DVR just provides a signal to your TV, just like the other two components. On the back of your TV there should be other connections to plug into like HDMI1, HDMI2, AUX1, etc. You select which input you want to view using your TV remote. For example, if you were watching a DVD, you turn on the DVD player. Say it was plugged into AV1 or something similar on the back of the TV. With your TV remote, select which input you are using...that way your TV receives the signal from your DVD player and nothing else.
Nov 16, 2017 | Onkyo HTR500 Receiver
Laptop into my YAMAHA HTR-6130 Receiver has Static
One possible reason would be a damaged ground in the cable (check with a DVD/CD player or any other device if possible to see if static persists.) if it is not the cable, then try plugging the laptop into the same power outlet as the Yamaha receiver and see if static persists. if static no longer persists, the problem is a discrepancy in the grounding on either end causing static in the signal and you can either buy a filter at most electronic stores. or you can just continue to use that power outlet if it is not an inconvenience. if it IS the cable, well, replacing it should be fine.
Jan 18, 2009 | Onkyo TX-SV444 Receiver
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
No sound
MAKE SURE THE RCA JACKS ARE RUNNING FROM "AUDIO OUT" ON TV OR DVD TO "AUDIO IN" ON RECEIVER.
Aug 25, 2008 | Onkyo HTR500 Receiver
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
