Http://192.168.1.1 is not working anymore? i cant set up the router
I got the router yesterday, at first 192.168.1.1 , the ip was working. later on it started not working at all. so i cant set up the router and use the internet connection. I tried to change my ip,default gateway,dns but none of them solved the problem. if anyone helps me,i'll be glad. thank you i can't access to tis router,thomsontg585v7. 192.1681.1 is not my default ip add
  • mannieface Jan 03, 2009
    my xbox 360 can find my ip numbe
  • Anonymous Jan 19, 2009
    i'am fucken modem !
Try 192.168.0.1 or 192.168.100.1
Posted on Nov 03, 2008
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
First thing to do when your router gives you problems: Unplug the power from the router, wait 5 minuted and plug it back in. Wait about 5 minutes (allowing time for the router to restart and reconnect) and try your connection again. If this solves your problem but the problem comes back after a while, do the same thing as above to fix it, go into your router settings and turn off the turbo mode.
Thanks for using the fixya forums!
Mar 27, 2009 | Linksys Wireless-G Broadband Router
so you can access the internet by getting connected by LAN cable. so now try to open the router by its default ip and look for the wireless securities setting and reconfigure them properly and if you are not able to access the router than there is reset button which reset the router to company default. and once you have reset the router than you have to configure it again as per your requirement.
Jan 08, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Reset the router and try again, To do that insert a pin into the small hole located on the back of the unit and keep holding a while till the lights go off and turn on again. Then release the pin and try again.
Dec 12, 2008 | Linksys Wireless-G WRT54GS Router...
Try pressing the reset button. If no button there should be a reset hole.
Mar 31, 2017 | Computers & Internet
you can not access the internet - maybe you will not read this..
Definately reset your router - and setup as you did previously.
Omit setting passwords until you have full confidence in the router and your own settings.
Aug 17, 2008 | NetGear WGR614 Wireless Router
Try resetting the router, press the reset button at the back for 10 seconds, after that release the reset button and then unplug the power of the router, then wait for 10 seconds and then turn it back on.
After that try accessing the IP of the router 192.168.1.1 (if this did not work try 192.168.0.1,this varies on the model number of the router). Or follow the same steps you have done previously.
Aug 15, 2008 | Belkin (F5D5231-4) Router
well, since you said that 192.168.1.1 was working when you first got it, you should try to reset the router (the button is on the back, press and hold it for 5 secs). that would be the easiest way to put your router back together.
Jul 30, 2008 | NetGear WGT624 Wireless Router
Computers & Internet Logo
1,619 people viewed this question
David Payne
David Payne
