Re: Hello
Do you know where I can download the user...
Do a Google search for LG website. There should be a search bar on the website itself and type that model number in and it should bring back your owner's manual.
Dear jnchahn Thank you for taking the time to suggest a solution to my dilemma. Unfortunately I had already tried what you suggested but the model is not listed on the LG website. I have now sourced a manual through other means thankfully. RosemaryDear jnchahn
Rosemary
You can't post conmments that contain an email address.
www.lg.com/au/support-product/lg-LD-1415M1 LG ElectronicsProduct Support. Home Appliances; Dishwashers; LD-1415M1. LD-1415M1 ... What should I do Low Rinse Aid indicator lightens up? Why is water not supplied ...
LG ElectronicsHome Appliances; Dishwashers; LD-1415M1. LD-1415M1. Search For ... What should I do when dishes are kept in a dishwasher after a cycle? Are plastic or ...
Simply click on the following link which will take you to the PDF downloadable users manual.
http://kitchen.manualsonline.com/ex/product/headline/m/lg/d/dishwasher/p/LD-2050SH
To me, it sounds like hard water deposits. This is happening because many state governments recently changed a law so that phosphate is not allowed in dishwasher detergent. Phosphate is good at cleaning the grit from your dishes, but it's bad for the environment. One solution is available from CitriClean of Florida.
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
When no leaks are found and you are getting an E1 error, the most common reason is that two things are true.
1.) The dishwasher drain hose does not connect to an airgap valve before it connect to the garbage disposal (or drain connection)
2.) That same drain hose does not have a high point in the hose between the dishwasher and the drain. This allows a natural siphon effect to pull the water out of the DW during the wash and rinse cycle.
The best solution is to install a dishwasher air gap on your sink and connect the drain hose to it and the air gap to the actual drain. They are almost free and any real hardware store.
But if the air gap is not possible, lift the drain hose as high as possible under the counter top and attach it so it stays up there.
