Acer L5100 and TV Tuner
Following on from other posts, there are no instructions for this PC and setting up the TV tuner in Windows Media Centre is driving me mad.
Starting from Media Centre I am going to TV setup, it prompts me for region (which is UK) and then asks me for signal input, which is satellite set-top box and then ask me if all the remote control stuff is set up properly, which it is (I have tried the cable from the set-top box to the PC and get a signal on a normal TV at around 800mhz).
I then get to the signal detect screen in Media Centre and select start scanning, almost immediately it comes back and says no signal found. And that's where I am stumped, tried everyting. Ned it to scan up beyond 800mhz and then it will find the set-top box input but it doesn't scan long enough to find anything!
Any help would be most appreciated.
  • San Diego JB Sep 17, 2008
    I need help with how to connect my ATT Uverse cable service to my VAIO. I don't have a clue how to actually connect the cable(s?); but I keep getting the message that no reception is detected. I can download the ATT fiber optic TV guide with all of the correct stations listed, but there is only a grey screen whenever I try to bring in any of the 386 channels.
    Any clues for me?
    Sergeant:
  • 395 Answers
Try normal arial first.
If OK, try freeview box again.
Check what tuner card you have fitted in Device Manager and check specs on google. Can it receive satellite freeview?
May be new drivers - check Tuner card website for driver updates and latest info.
reply back with what card is fitted.
Posted on Aug 08, 2008
SOURCE:
How do I check the CPU cooling fan setting in the BIOS please ? I also understand my PC has a TV tuner - how do I access it please ?
On startup push F2 (or DEL or F12) to enter setup/bios.
As for the tv tuner, you'll need to connect Cable TV to it then use some software such as Windows Media Center, to view the channels.
Oct 16, 2014 | Dell (6F858) Cooling Fan
No tuner error on sony media center
Hi
The problem must be either because of Hardware or software. You are saying that you already tried installing new drivers and softwares for the tuner card and checked, but its bad luck. So it seems the hardware device may be failed. So first ensure the hardware working properly by plugging tuner card into any of your friends system. If it works properly, then it must be surely software problem. We can try installing any other version of device drivers and softwares and make it work.
Goood luck.
Sep 09, 2008 | Sony VAIO VGN-AR230G Notebook
I NEED NEW DRIVERS FOR WINDOWS MEDIA CENTRE 7 ON
Get connected to the internet and download the necessary driver software for windows media center.
Nov 07, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Cant copy recorded tv
fixed thank you.when you install dvb-t tuner software DONT let it search for available channels dont set it up just install the operating program. then using windows media centre scan for available channels. i think there is a conflict of interest between the media centre program and the dvb-t stick program. mine is pinnacle studios.the stick needs to be in the usb on boot up to be recognised.this works a treat and thinking about it could be the cause of many windows media crashes when two tuners are competing for the same signal.
regards
steve
May 17, 2009 | Toshiba Satellite Pro L350-S1001V Notebook
I nee a Tv Tuner for my computer.
Look into ATI products for your tuner needs they will work with media center, Make sure you get a digital and analog tuners so that you can have the best of the two on one card, Best of luck to you on your purchase.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 15, 2009 | Computers & Internet
Used to watch tv through windows media centre on vista. Then moved my computer to another room, set it up the same way, now says there is no tv tuner?
If the TV tuner is USB, try shifting it to another USB port.
If the tuner is internal, turn off the PC, unplug the power cord from the wall, and open the PC. The card may have popped out of the PCI (or PCI express) slot when in transit. Then try again.
Dec 07, 2008 | Acer Computers & Internet
Windows media centre 2005
Hi, and thank you for the reply,
I am not very tech, and cannot find any info to tell me what tv tuner it is,
there is nothing in the documents , and when I check..."device manager" for information on the installed hardware,there seems no mention of the tv tuner.
Can you advise me where the advice is?
It used to work fine when I had it at first.....so know it must be me! Thanks again Brian
Aug 12, 2008 | Microsoft Windows XP Media Centre 2005 for...
Ive got a twin tuner tv card 1 tuner digital the other analogue im on windows vista but the media centre will only tune the digital i cannot find how to get the analogue tuner to work.
Vista will only work with digital signals, you may need to install a software program or hardware to switch from anolog to digital.
Mar 21, 2008 | Computers & Internet
Getting windows media to work with tv tuner card
its is due to the older tv tuner card drivers doesnot supports for windows mediacentre try to update driver if not change for new tv tuner card which supports mediacentre.
Feb 24, 2008 | Creative Labs Sound Blaster Live! 5.1...
How to set up TV tuner on HP laptop to receive freeview channels.
better contact HP service center as it is still under wtty. I can guide you but no use wreking your brains over what can be done in minutes by HP technician.
Sep 22, 2007 | HP Pavilion dv9000z Notebook
Open Questions:
SolutiOn**_++l~855-892-OO6O } APPLE ipad SuPpOrT [email protected]? apple iphone tech support phone number iphone support number apple iphone phone number customer service iphone phone number customer service apple mac air support number apple mac air technical support apple mac air tech support ipad tech support number ipad technical support number apple ipad tech support number apple tech support number for ipad apple ipad tech support number apple tech support number for ipad apple mac technical support number apple macbook support number macbook air support phone number apple macbook pro support number apple ipad technical support number apple ipad support number apple macbook pro technical support apple support for mac air apple support for macbook air itunes customer service number billing itunes app customer service number itunes support phone number usa itunes support number usaApple Support in Sweden Help You With Apple Product Issues Welcome to Apple Support in Sweden! We are here to help you with any problem you face with your Apple device. We have a team of Apple certified engineers who can provide the exact solution to your problem. Dial our toll-free Apple Customer care number Sweden and talk to our support executives. Wondering about the service we offer? Moving forward, we are not going to just babble on about the service we offer, like any other company out there. Better, have a look at our services... Apple Customer Support Sweden: Our Featured Services Apple has a wide range of products. With such high-end products, the amount of complexities also increases. Thus, we have a dedicated team of experts who can assist you with any issue on any Apple device. Here, is what you can get from us. Apple Mac Support Are you having a problem with your MacBook? Then you can come to our professional computer engineers available at Apple Support in Sweden. These are the most common issues Apple users face at least once: Can't install software from iTunes Unable to update MacBook to the latest version Not being able to perform disk partition on MacBook Pro Can't Connect MacBook to the Wireless Internet Connection There are lots of other issues as well with which we can help you. Call our Apple Support in Sweden and get the experts' assistance in no time.
Oct 15, 2019 | Apple Computers & Internet
SolutiOn**_++l~855-892-OO6O } APPLE Macbook SuPpOrT NumBer @!wds apple iphone tech support phone number iphone support number apple iphone phone number customer service iphone phone number customer service apple mac air support number apple mac air technical support apple mac air tech support ipad tech support number ipad technical support number apple ipad tech support number apple tech support number for ipad apple ipad tech support number apple tech support number for ipad apple mac technical support number apple macbook support number macbook air support phone number apple macbook pro support number apple ipad technical support number apple ipad support number apple macbook pro technical support apple support for mac air apple support for macbook air itunes customer service number billing itunes app customer service number itunes support phone number usa itunes support number usaApple Support in Sweden Help You With Apple Product Issues Welcome to Apple Support in Sweden! We are here to help you with any problem you face with your Apple device. We have a team of Apple certified engineers who can provide the exact solution to your problem. Dial our toll-free Apple Customer care number Sweden and talk to our support executives. Wondering about the service we offer? Moving forward, we are not going to just babble on about the service we offer, like any other company out there. Better, have a look at our services... Apple Customer Support Sweden: Our Featured Services Apple has a wide range of products. With such high-end products, the amount of complexities also increases. Thus, we have a dedicated team of experts who can assist you with any issue on any Apple device. Here, is what you can get from us. Apple Mac Support Are you having a problem with your MacBook? Then you can come to our professional computer engineers available at Apple Support in Sweden. These are the most common issues Apple users face at least once: Can't install software from iTunes Unable to update MacBook to the latest version Not being able to perform disk partition on MacBook Pro Can't Connect MacBook to the Wireless Internet Connection There are lots of other issues as well with which we can help you. Call our Apple Support in Sweden and get the experts' assistance in no time.
SolutiOn**_++l~855-892-OO6O } Macbook air SuPpOrT phone NumBer?sddss apple iphone tech support phone number iphone support number apple iphone phone number customer service iphone phone number customer service apple mac air support number apple mac air technical support apple mac air tech support ipad tech support number ipad technical support number apple ipad tech support number apple tech support number for ipad apple ipad tech support number apple tech support number for ipad apple mac technical support number apple macbook support number macbook air support phone number apple macbook pro support number apple ipad technical support number apple ipad support number apple macbook pro technical support apple support for mac air apple support for macbook air itunes customer service number billing itunes app customer service number itunes support phone number usa itunes support number usaApple Support in Sweden Help You With Apple Product Issues Welcome to Apple Support in Sweden! We are here to help you with any problem you face with your Apple device. We have a team of Apple certified engineers who can provide the exact solution to your problem. Dial our toll-free Apple Customer care number Sweden and talk to our support executives. Wondering about the service we offer? Moving forward, we are not going to just babble on about the service we offer, like any other company out there. Better, have a look at our services... Apple Customer Support Sweden: Our Featured Services Apple has a wide range of products. With such high-end products, the amount of complexities also increases. Thus, we have a dedicated team of experts who can assist you with any issue on any Apple device. Here, is what you can get from us. Apple Mac Support Are you having a problem with your MacBook? Then you can come to our professional computer engineers available at Apple Support in Sweden. These are the most common issues Apple users face at least once: Can't install software from iTunes Unable to update MacBook to the latest version Not being able to perform disk partition on MacBook Pro Can't Connect MacBook to the Wireless Internet Connection There are lots of other issues as well with which we can help you. Call our Apple Support in Sweden and get the experts' assistance in no time.
Computers & Internet Logo
118 people viewed this question
Ekse
Alun Cox
