The Fisher EQ-550 is a vintage graphic equalizer, and issues with specific LEDs not working could be due to various factors:
1. **LED Bulbs:** If only specific LEDs (like the TAPE MONITOR and REC EQ LEDs) are not working, it might indicate a problem with those specific bulbs. They might be burnt out or loose.
2. **Internal Connections:** Check internal connections and wiring to ensure they are secure and not damaged. Loose connections or damaged wires might cause LEDs to malfunction.
3. **Control Switches/Modes:** Ensure that the EQ-550 is set to the correct modes or settings that activate these LEDs. Sometimes, certain settings might deactivate specific indicator lights.
4. **Component Failure:** If multiple LEDs are not working or if there are other issues with the unit, it could be a sign of component failure within the equalizer. This might require professional repair or replacement of internal components.
Due to the vintage nature of the EQ-550, finding replacement parts or professional repair services might be a bit challenging. You can try basic troubleshooting like checking connections and ensuring the unit is set to the correct mode. If the issue persists, seeking assistance from a specialist in vintage audio equipment or contacting a repair service familiar with older audio gear might be the best course of action.
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
It goes between whatever you are using to create the sound and the input to the amplifier. e.g. for a standard HiFi.. HiFi aux out to equalizer input... equalizer output to amplifier aux input. Trying to keep left and right channels the same through out. They are usually colour coded. Red = right Left = white. Hope that helps. We all start somewhere
