Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Roaring vacuum My vacuum begins to roar shortly after I turn it on. The sound seems to be coming from the middle of the canister. When I take the recoil cord off, there is a plate just under it still on the canister that is extremely hot. Any idea what could be wrong and how to fix it?
Good day,your problem seem that it is plug if you have no suckiong ,place the hose on the exaust that should un plug the hose,or the motor has had some dirt et it and plug the intake ,that is why it roars try this,later
Posted on Sep 11, 2008
Why is the motor roaring ? is it rubing on housing or a bearing ?
It may not be you motor, but the sound of some item caught in the impellar, which is the part that causes suction. It is usually located in the upper housing, and can be accessed fairly easily. Unscrew any visible screws,(usually phillips type) and carefully lift housing off. This should expose the impellar. If debris is present, remove it.
But also check for possibly broken fins on the impellar itself. Sometimes items like coins, or nails etc, will get picked up accidentally, then spin around in the impellar housing, only to break a fin or two trying to move on. If this has happened, replace the impellar.
Dec 22, 2015 | Hoover UH70105 WindTunnel TSeries Bagless...
My kenmore progressive canister vacuum turns on only if the hose is attached to the floorwand. It seems that the canister motor is not working because I can't hear anything coming from the caniste
If the floor wand is powered, there may be an electrical connection that is broken when the wand is disconnected. This is part of the design, not necessarily a fault
Jan 05, 2013 | Vacuums
I think the motor has blown. When turned on the vacuum makes a very loud, low roaring sound and it smokes terribly.
Yep, you are correct! Unfortunately, it's probably time to get a new one. I wish I had better news for ya.
Good Luck!
Jim
Aug 06, 2011 | Philips Vacuums
Canister turns on but no suction in house
sounds like there could be a clog in the lines, Check the pipes running through your attic/basement, and see if there's something blocking the piping.
If you can't seem to find the problem, I'd suggest looking into having someone who services central vacuums come and take a look. They'd have the proper tools and knowledge to help you in person
Apr 19, 2010 | Eureka 1810 Central System Vacuum
My Kirby 2HD has started making an odd roaring noise but still works fine. I have taken the front assembly off and cleaned and adjusted the roller and checked the belt. The noise seems to come from the...
It is quite possible, it just needs lubed. The motor comes in direct contact with dirt so, you have to make sure the front bearing has a drop of oil on it from time to time. If it starts to scream at you within one month, after oiling, the bearing needs to be replaced.
Oct 05, 2009 | Kirby Heritage II Vacuum
Dyson DC07 is very loud, roaring from the motor
It usually gets louder as the filters clog up and eventually burns out. Try replacing all the filters and giving the bin and the vortex generator a good blow out with compressed air. Fluff can stay inside and cause the motor to strain hence the increased noise.
It must still be under warranty -used to be 3 but now 5 years -so if it doesn't improve contact Dyson and they will repair it free of charge.
Mar 17, 2009 | Dyson DC07 All Floors Bagless Upright...
Hi folks, my beam vacuum makes a very loud roaring noise quite often. the problem started when i was vacuuming up a quantity of vermiculite from my chimney. i think i overloaded the vacuum i think and...
If the filter bag is bad and didn't trap all of the dust, then it got into your motor, so you may have a problem with your motor now.
Apr 20, 2008 | Vacuums
TROUBLE WITH MY SHAMPOOER
A rubber smell could be a belt and/or brush roll. But a loud roaring noise could only be from the motor, which would mean replacing it if that is the cause.
Feb 13, 2008 | Eureka 2576A Steam Vacuum
Bissell 8990 CleanView Bagless Upright - Loud noise
Sounds like maybe your motor went bad, part # 2031052. Would sell for about $60. When the bearings go bad, they can be real loud as well if the fan on the motor when it gets damaged.
Dec 30, 2007 | Bissell 6590 CleanView Bagless Upright...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
61 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
