Question about Dometic Rooftop RV Air Conditioner
Ac and heater wont work
I have a 94 prowler fifth wheel. The heat and ac won't work, what should I look for?
  • Dometic Master
  • 6,674 Answers
Do you hear any clicking at all ( up near AC or down near furnace, when you move the thermostat ? Have you checked you breakers & fuses in the trailer?
Posted on Aug 14, 2008
Truma water heater water wont come out of the taps when on gas, 12 volt or mains 240 volt
Bleed your propane system by running the stove for a sec. if that doesn't work go out to the heater and listen for the ignitor clicks see if it's trying to lite. My fifth wheel does this first time every season.
Feb 22, 2015 | Water Water Heaters
1999 fleetwood prowler 25 5b
You need to visit a local dealer...any RV dealer. They should provide a general walk through as a courtesy. Pay them for a maintenance inspection and they can provide a detailed explanation of their work. After that you might be able to troubleshoot/repair simple problems yourself.
Feb 15, 2014 | Water Heaters
No power to my refrigerator and heater
Did you check the fuses in the AC/DC breaker panel? Also, verify the GFI is not tripped.
Oct 23, 2012 | Tools & Hardware - Others
I have a 1979 dometic fridge in my fifth wheel and it will not work off electric even though it did before, any ideas?
if out let on back of fridge ok then see if 12 ac volts to board check heater element or fuse
Aug 23, 2012 | Dometic RM2652 Refrigerator
Chrysler Fifth Avenue 1986 fuse problem
It will most likely be the motors in your windows. My driver front and back right window won't go down either. Your AC and Heat your switches might have just worn out in the whole container. I'd go to a mechanic and check that out. Hope this helps!? Sorry I can't be of more assistance.
May 31, 2009 | 1986 Chrysler Fifth Avenue
Rv domatic a/c and heater
Need to know what your air conditioner make & model is. Are you running air conditioner & furnace off same thermostat, or are they on separate ones?
Jul 26, 2008 | Dometic Rooftop RV Air Conditioner
Rv air conditioning
You may have to remove your filter & look for a model # of your unit, so we can pinpoint your wiring to the thermostat. Usually the terminals on the thermostats are labeled -RC-RH- etc, and you simply move old to new of the same. A lot of times some manufacturers will use phone cable form AC unit to thermostat, and mix up the colors, that's the reason for going to the AC and see what color is used from there. It could be red from control box, connected to green wire to thermostat for example. Thats where you note it and wire accordingly.(terminal calling for red wire, would now be green) If your stumped, get back to us with that model#.
Jul 12, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
282 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
