My hard drive want turn on - Computers & Internet
  • Josh Hamman
    Josh Hamman May 11, 2010
    Did you mean to say it WONT turn on? and is it just your harddrive or your whole computer that wont turn on?
    Sergeant:
  • 395 Answers
Disconnect the data cable and switch on computer. If it does not spin then it has had it!
Posted on Aug 08, 2008
My dell windows hard drive won't turn on .. It's was working now it won't turn on there's an orange light inside the box we can see but it won't turn on
The hard drive may be failing, or just the OS or hard drive corrupted. You could try this. Pull the hard drive out, and use a USB Hard Drive Adapter to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Jul 08, 2014 | Computers & Internet
Unmount usb
External hard drives are portable storage devices you can use to back up files or transfer content from one computer to another quickly and safely.
While external hard drives vary in design and storage capacity, turning them off properly is ideal because it decreases the chances of damaging or corrupting files.
Whether you are using Windows or Mac OS X, you can safely eject and turn off your external hard drive in minutes.
Safely eject your external hard drive before turning it off if you have connected it to your computer.
To do so, click the "Safely remove hardware" icon on the system tray on the taskbar. T
he hardware window launches.
Click your external hard drive's icon in the hardware window and click the "Stop" button. You should see the "This device can now be safely removed from your computer" dialog message.
Press the "Power" button to turn off your external hard drive.
Some external hard drives turn off automatically when you safely eject them.
Right-click your external hard drive's icon on the desktop if you are using a Mac, and then click "Eject."
Alternatively, drag your external hard drive's icon from the desktop to the "Trash" bin.
You should no longer see your hard drive on the desktop.
Feb 05, 2014 | Transcend Computers & Internet
Hard drive clicks won't turn
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Oct 20, 2012 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
How to set a toshiba hard drive to slave?
Power off the Toshiba laptop. Remove the power cord and the battery.
Turn the laptop upside down and remove the panel where the hard drive goes with a screwdriver.
Depending on the model of Toshiba laptop being worked on, this may include the entire bottom panel, a panel covering both hard drive slots or a panel covering the empty second slave hard drive slot.
Install the second hard drive by inserting it into the open slot.
Replace the opened cover.
Replace the battery and power cord.
Turn on the computer.
The second hard drive is automatically configured as the slave drive.
Depending on the operating system and previous status of the slave hard drive, it may need to be partitioned or formatted before being used by the operating system.
hope this helps
Sep 13, 2012 | Toshiba Computers & Internet
Aspire one can not detecthard drive
Repair laptop hard drive is not detected
Solution 1
1. Open the hard drive cover (remove two screws)
2. Remove the hard drive screws, then slide the hard drive (see the arrows)
3. Wait 15 minutes, then plug the hard drive
4. Turn on the laptop.
Solution 2
1. Remove the hard drive
2. Clean the gold layer with a pencil eraser
3. Plug the hard drive, then turn on your laptop
Solution 3
2. Plug jumper on the hard drive
Solution 4
1. Remove the hard drive, plug the external cable.
2. Connect the hard drive to another computer, with USB connection
3. If the hard drive can be detected, eject the hard drive
4. Plug the hard drive to the laptop, then turn on
Intended to make the hard drive can work with the help of another computer
Solution 5
1. Remove the laptop hard drive
2. Plug the laptop hard drive to my PC.
SATA1 - PC hard drive
SATA2 - Laptop hard drive
3. Boot the computer from a PC hard drive
The purpose of using a PC computer main-board as drivers of the laptop hard drive.
I hope this information helps. Thank you for using FixYa!
Oct 15, 2011 | Acer Aspire One PC Notebook
It went in for service when we got it back it only turned on once. now when we turn it on the screen is black and on the top left corner the cursor is flashing and if you press on a key it makes a loud...
There are two possibilities, damaged memory and hard drive not detected or damaged. Most likely is, the hard drive is not detected or damaged. The characteristics of the hard drive is damaged, when you turn on your laptop, you are like the sound of this
To be sure, the hard drive is in trouble, press F2 to enter BIOS, check your hard drive, or check the hard drive is detected or not.
If the hard drive is not detected and didn't sound the hard drive is damaged (like in the video), the hard drive can be repaired and the data can be saved. Solution: take it to the Service Center.
If the hard drive is not detected and the sound of damaged hard drives, optical damage your hard drive. Solution: replace the hard drive.
Sep 23, 2011 | Computers & Internet
Not being recognized after updating drivers on MK8025GAS
Maybe your hard drive are not inserted properly in the motherboard, just check the connection. Turned Off you computer and check all connection on the hard drive then turn it on again. And try to go the CMOS or BIOS setup by pressing the Delete key on your keyboard and then try to see it the hard drive are detected by the BIOS. It it is detected your hard drive are ok but if it is not you have a problem for your hard drive and try to replace the hard drive.
May 28, 2010 | Toshiba MK8025GAS 80 GB Hard Drive
Hard drive not working
Hi,Make sure the hard drive is fully inserted into the hard drive bay and looks level. Turn the console off, then on again.Turn the console off and remove the hard drive. Turn the console on and then off again. Reattach the hard drive.If available, try the hard drive on another console, or try another hard drive on your console to pinpoint the problem.
Thank you!
May 12, 2010 | Microsoft Xbox Console
No connection to WD hard drive
just change the usb cord the problem is in the usb
Mar 05, 2010 | Western Digital My Book Essential 1TB...
Reseat the hard drive
Hi, You can try this out to reseat the Hard Drive
First safety Steps:
  1. Ensure that the work surface is flat and clean to prevent the computer cover from being scratched.
  2. Click Start before7.jpg , click the arrow before8.jpg icon, and then click Shut Down to turn off your computer.
  3. Disconnect your computer and all attached devices from their electrical outlets
  4. Disconnect any telephone or network cables from the computer.
  5. Remove any installed cards from the ExpressCard slot and the 8-in-1 memory card reader
  6. Turn the computer over.
  7. Slide the battery release latch until they click into place.
  8. Slide the battery out of the battery bay.
  9. Turn the computer top-side up, open the display, and press the power button to ground the system board.
    battery
1. Turn the computer over and remove the two hard drive screws.
screws (2)
hard drive
2. Slide the hard drive out of the computer.
3. Slide the hard drive into the hard drive bay until the drive is fully seated.
4. Replace the two screws to secure the hard drive Then again you can try
Feb 03, 2009 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
