Question about HP LaserJet 4200 Printer
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
HP LaserJet 4200 won't print envelopes from tray 1. Printing from tray 2 works fine. Printing to regular paper from tray 1 works fine too. Just won't print on envelopes from tray 1. Help!
  • 3 more comments
  • Anonymous Mar 13, 2014
    HP Laserjet 1320 won't print envelopes
    The envelope goes through but comes out without the address printed on it.
  • Anonymous Mar 17, 2014
    HP 4000 laserjet keeps asking for paper in tray 2 and its full
  • Anonymous Mar 27, 2014
    when attempt is made there is a (no paper pickup message)
    Problem Solver:
  • 25 Answers
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
SOURCE:
Envelopes don't feed properly
When printing envelopes, you have to set tray1(the bypass tray) to handle the envelopes in the menu.
Configure trays (HP LaserJet P2050 Series Printers only)
1. Press OK.
2. Press the down arrow to select System setup, and then press OK.
3. Press the down arrow to select Paper setup, and then press OK.
4. Press the down arrow to select the desired tray, and then press OK.
5. Press the down arrow to select Paper type or Paper size, and then press OK.
6. Press the down arrow to select the size or type.
7. Press OK to save the settings.
Feb 26, 2015 | HP Laserjet P2055 Printer Laserjet 1200 X...
PRINT RUBS OFF
When printing envelopes ensure you set paper/media type to Envelopes, and feed via tray 1/bypass . Paper type setting sets correct fuser temp, the fuser is the hot bit at the rear that "melts" the image into the paper.
If paper type is set correctly then I recommend you change the fuser unit.
Ensure envelopes are standard type. ie you are printing on paper envelopes
Feb 11, 2008 | HP LaserJet 5p Printer
I am using hp 3505 color lesser printer on windows 7 32bit, Driver that was installed automatically by windows is "HP Color LaserJet CP3505 PCL6" My tray 1 that is multipurpose tray is printing slo
Make sure that you have tray 1 set for the correct paper type. Leaving the paper type as unknown will result in very slow printing as the printer will assume that it might be printing on heavy media, envelopes or the like.
Feb 02, 2015 | HP Office Equipment & Supplies
4200 PRINTER Only wants to print out of tray 1
First you need to verify that tray 2 will print from diagnostics test. Use the arrow keys to scroll down to diagnostics and press arrow key, then use arrows move to paper path test and press arrow again. The default paper path test is tray 2 single copy so just select print paper path test and see what happens. If printer prints from tray 2 then we know tray 2 works and that means you either have a print driver that is forcing printing from tray 1 or your settings on the printer for tray 2 are not correct for what you are printing. Check to make sure the paper size shows correctly and make sure that the switch on the right side of the paper tray towards the back is set for standard and not custom.
Aug 04, 2014 | HP LaserJet 4200 Printer
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Re HP Laserjet 4P after inserting envelope to print, upon giving PRINT command, printer will not print and indicates PAPER JAM. However, there is no real paper jam. No problem printing regular 8 1/2 x 11...
Most likely a bad pick up roller these machines will give a jam error if the paper or envelope is not picked up. Try cleaning the roll for the tray you are having the trouble with if the condition improves you have found the problem.
Hope this helps
Apr 19, 2009 | HP LaserJet 4 plus Printer
HP 3600dn Duplexing Issue
Manual 2-sided printing. Most of the supported media sizes and types listed for printing from tray 1 can be manually duplexed. Do not use the 2–sided printing feature on transparencies, envelopes, or labels.
I found this note in the 3600 service manual. Maybe it will help.
Mar 06, 2009 | HP LaserJet 3600dn Printer
Can't Print Envelopes, No Ink being used
Set tray 1 for the correct size envelopes in printer properties.
Feb 21, 2009 | HP LaserJet P2015dn Printer
HP LaserJet 4200 Printer Logo
1,757 people viewed this question
Clive
Clive
Thomas F. Schneider
