Question about Haier Energy Star ESA3183 Air Conditioner
Central air and heating, not cooling
The whole system has been cleaned but it still doesn't cool. A ciruit breaker on the air handler was replaced, after it was turned on it smelled like the heater was also on. Refrigerent was put into the compressor and it kind of cooled but not enough,(note: the compressor is also working fine according to the pressure readings.)
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Need to have checked out by a diagnostic ac man.
Posted on Sep 07, 2008
SOURCE:
Central ac compressor keeps running
Sounds like the contactor is stuck. Turn the power off on both units and remove panel on condenser. Pull out on the contactor if engaged. Likely still needs replaced, it's going to happen again.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 25, 2017 | Heating & Cooling
Central air conditioner unit comprssor doesn't come on i suspect a lightening storm did something while we were away
check main power breaker, and reset breaker on unit, otherwise lightning storm would have nothing to do with units problem other then power surge, which would trip a breaker. Hope this helps, Thanks Mikemc1bean.jpeg
Jun 23, 2011 | LG Heat cool Window Air Conditioner
I'm installing a Honeywell Thermostat RTH2410. In Step 1 you need to identify the system type. I have a Carrier Heat Pump model FA4BNF030. Is this a heat pump with or without auxiliary/backup heat?
Auxiliary heat is electric heat that is put into the air handler on the inside of the house. Its used when your heat pump doesn't provide enough heat, but heat strips are not always used. To see if you have auxiliary heat, look inside and see if you have breakers on the front panel of the air handler or anywhere close. No breakers, no electric heat. Hope this helps!
Dec 11, 2010 | Honeywell Electronic Programmable...
I want to replace a system
Hello
Tons of cooling is in btus.12000 btus is one ton,24000 is 2 tons.
Somewhere on your unit is the cooling capacity in btus,take that number and divide it by 12000.
Usually a 2000 sf house will need 3 to 4 tons of cooling,more is always good.
Im sending a link to do an easy calculation that should be helpful.
http://www.consumerreports.org/cro/appliances/heating-cooling-and-air/air-conditioners/sizing-worksheet/
Jun 01, 2010 | Ruud UBHC Air Conditioner
The furnace part of my central air is wired to a seperate breaker but keeps tripping the breaker and making a spark in the breaker box.
Usually a Central Unit is wired seperate, the Air handler inside and the
Cooling unit outside. It appears that the breaker is bad, is it a Single Pole Breaker?
Another possibility is that the indoor blower motor might be bad.
Jan 10, 2010 | Heating & Cooling
We have 2. LA125HV w/ 1 condensing 1. air handler
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
Dec 07, 2009 | LG LA125HV Split System Air Conditioner
Can somebody help,why is my Central AC blows
Most heat pumps have an auxillary heat. Many are electric auxillary heat with a heat strip in the air handler. A common malfunction is for the electric auxillary heat to operate when the heat pump is set on cool. To confirm this, locate the conductor that runs from the heat sequencer to the connection on the heat strip. You will see this on the top section of the air handler. Use the clamp on part of the amp meter over that wire. If the thermostat is set on cool and the heat strip is drawing amps, it means the heat is coming on while the heat pump is set on cool. There is usually one or two causes for this, either the sequencer is bad or there is low voltage wires usually behind the thermostat or in the air handler closet that are touching that shouldn't be touching.
If this is not the case, if its not a problem of where the heat is coming on with the air conditioner, it could be a case of the reversing valve malfunctioning. The way a heat pump works is it reverses the flow of the refridgerant. For instance, many heat pumps the reversing valve is activated in cool. That would mean that there is a low voltage circuit that activates the reversing valve when the heat pump is in cool. I'm not sure what model/brand your heat pump is, Goodman and Janitrol for instance, the heat pump reversing valve is activated in cool. In any case, if the reversing valve is not operating properly, when the air conditioning is set to cool it will actually be heating. Or you could set it to heat and it may actually be cooling instead of heating. Please check these two items first and if you have any further questions, please let me know. Especially if you know of any additional problems like the evaporater is icing up or if the air handler fan is not operating when it should.
Aug 31, 2009 | Heating & Cooling
Central Air, its a Trane, cools, however not very well. I think it needs a charge
First I would check your filters inside the furnace or air handler. Then if you have access I would check the a-coil. Sounds to me like you have a problem in the area of where the system transfers heat from the inside to the outside. Another thing that would'nt hurt would be to clean your condensing unit outside.
Jun 22, 2008 | Heating & Cooling
Central air conditioner doesn't cool
A central air conditioner that runs but doesn't cool may just need to be cleaned. Plan to do this on a relatively warm day. First look for your owner's manual and, if you can find it, follow its instructions. If you can't find it, request one from the manufacturer (see Resources). To clean the filter, remove it from the furnace or air handler (it?s usually located inside or very near the air inlet side). Replace a disposable filter or clean a reusable filter according to the manufacturer?s directions. 1) Before you begin, check the thermostat to make sure it is set to "cool" rather than "heat." Then turn off the power to the unit; there is normally a shut-off or disconnect panel on the house wall next to the outdoor compressor. Otherwise, shut off the air conditioner's 240-volt circuit at the main electrical panel. 2) Rake leaves and debris away from the outdoor condenser. 3) Remove any protective grille or cover from the condenser's fins. 4) Use a soft brush to clean dirt and debris from the fins, then vacuum them with a brush attachment (be careful not to bend or damage them). If you accidentally bend fins, you can buy a comb made for straightening them at an appliance parts store. 5) Unscrew and lift the top grille off the unit, if possible. If the fan is attached to the grille, be careful not to pull any wires loose. 6) From inside the unit, hose out the fins (protect the wiring and motor with plastic). If your owner's manual calls for lubricating the motor, do that now--don't over-lubricate. 7) Then reassemble the unit. 8) To test it, turn the power on and set the thermostat to turn the unit on. Let it run for a few minutes, then feel the two pipes that connect to the condenser unit (slide any insulation back). One should feel warm, the other cool. Otherwise, call an air conditioning technician--the refrigerant may need to be recharged. NOTE: Avoid straining an air conditioner's compressor by waiting at least five minutes between turning it off at the thermostat and turning it back on. Air conditioner or heat pump still giving you trouble? To Home Problem Solver Main Page Copyright. All rights reserved. Interested in licensing this DIY Content? Related terms: what to do if, how to fix, troubleshooting, DIY, air conditioner doesn't cool, air conditioner too warm, warm air from air conditioner, air conditioner not cold enough, how to clean air conditioner, cleaning air conditioner, air conditioner cleaning
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
133 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Bill Jennings
Bill Jennings
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
