Question about HP LaserJet 4 plus Printer
Toner ink Dear Expert Please how do i personally replace a new "Toner Ink Cartidge" of my Laserjet 4 plus printer. Tanx
    Master:
    Sergeant:
  • 398 Answers
Okay, open the top lid and you will see the cartridge pointing toward you, this is a large black looking plastic device. Reach in a grab it and pull it outward. it comes out fairly easy. Notice which end is toward you. To install the new one, first check to see the strip of plastic that needs to be pulled out. pull it and discard it. Then push your new one down in the same place the old came out of. It will kinda wiggle up and down going in, and if it doesn't go all the way in, pull it back out and push in, it usually goes right in place with no trouble, I have one of these printers for 8 years and it has never failed me, great machines.
Posted on Aug 08, 2008
    Master:
  • 521 Answers
Lift the top cover the cartridge is fitted inside slowly pull the cartridge towards yourself and remove remember the position of the cartridge properly and the same way insert the another cartridge slowly and carefully.its simple.
645a HP refill
Try a cost efficient compatible ink to replace the HP cartidge. See the link below for a great alternative.
http://inkandtonerlocker.com/products/2-21-3314
Oct 19, 2013 | HP 645A Magenta Toner Cartridge (C9733A)...
Can't change ink cartriges
Hi
First of all be advised that this is a laser printer and the toner cartridge needs to be replaced.
Follow the steps below
1. Press the blue button on right side of the printer
2. Lift the toner cartridge a little up (This will unlock the cartidge from the holders)
3. remove it slowly and do not force remove the cartridge.
4. The new toner cartridge needs a little care to install
Check this link for step by step instructions of HP.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=es&cc=uy&taskId=125&prodSeriesId=1140783&prodTypeId=18972&objectID=c02709218
Jul 11, 2011 | HP LaserJet 3050 All-In-One Printer
14 no toner cart
when top door , and check for the sensor switch
Jun 17, 2010 | HP LaserJet 4 plus Printer
Do you get a new drum with a toner replacement cartidge or is it a separate thing you have to buy
Hello.
The drum and toner cartridge are separate items. Both are replaced by the user.
The toner cartridge holds toner/ink. The drum does the work. You will need to replace the drum for every 4-5 toner cartridges used.
I've seen toner cartridges for your printer at $36 vs $60 for a drum.
Hope this helps.
Jun 13, 2010 | Brother MFC-7440N Laser Printer
The yellow spot is blinking and the black dot is
the solid light means toner is low. Blinking usually means either the cartridge is out of toner or the cartridge is having a technical problem. If you pull the yellow toner cartridge and put it back in with no change in result, you will need to replace the yellow toner cartidge
Nov 19, 2009 | HP LaserJet 1500L Printer
Error code 14 "no tuner cart"
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller
May 06, 2009 | HP LaserJet 4 plus Printer
Smudged Printing
replace the toner. many remanufactured cartridges will do this due to leaks during/after refill.
Nov 07, 2008 | HP LaserJet 4 plus Printer
Dirty Copies
clean the ink box from printer where the cartidge park
Mar 20, 2008 | HP LaserJet 1012 Printer
HP LaserJet 4 plus Printer Logo
Seeker5211
Seeker5211
