Question about Trekstor Beat censo 73812 MP3 Player
TREKSTAR 256 mb , ver 2.512
N able to play MP3 songs, unit will be hung ,and I have to remove battery for remove this hanging.
how to correct this problem?
How can i fix my mp3 player
Possible that the player had hung up due to faulty files. It will be best to connect and scan for virus or improper files, if not remove and reload with valid files that will clear the fault.The processor seems to hang as it detects a malware and so the white screen.
Oct 18, 2011 | Mach Speed TRIO Onyx MP3 Player
I want to increase its capasity of loading song from 256 mb to 8 gb
The AZ-ES256 is a very basic MP3 player and has no option for expanding it's memory.
If you need more memory, your only option is to buy another player.
There are a number of Mp3 players around, and some have a slot to put in a microSD card to give you more memory.
You could also look at a MP4 player. While you can play movies on them, you don't need to, they will still play music. Many have 16GB of memory.
Feb 02, 2011 | Aiwa Pavit AZ-ES256 (256 MB) MP3 Player
Philips PSS110/17 256 MB MP3 Player froze at the start of a song .Hit reset button nothing happens?
Waited till battery fully discharged. Plug charger back in, all functions restored..
Sep 21, 2008 | Philips PSS110/17 MP3 Player
My I-bead mp3 was formatted accidentally...
Your songs are most likely gone, formatting erases all of the data on the player.
Always back up your data on a seperate disk. Good luck.
Mar 08, 2008 | Electronics - Others
Lyra RD2312 freezes when chosing song to play
I had the same problem a couple of monthes ago. I solved it by upgrading the firm ware to version 3.11. Worked fine since then.
Feb 29, 2008 | RCA RD2312 (256 MB) MP3 Player
Tsonic 610 is not working well!
Upgrade to new version of firmware. I think the latest is ver 3.4. Good luck.
May 29, 2007 | Transcend T.sonic 610 MP3 Player
Please refer to this quick start guide... http://www.p4c.philips.com/na4/p/pss110_17/pss110_17_qsg_aen.pdf ...or if you need extensive details download this userguide http://www.p4c.philips.com/na4/p/pss110_17/pss110_17_dfu_aen.pdf Also, for more details on this device, refer to the support page mentioned below http://www.usasupport.philips.com/productDocuments.html?ProductCode=PSS110/17&subCat=SHOQBOX_SU_US_CONSUMER Those are pretty easy to follow instructions. Just do the right steps. Cheers
Mar 14, 2007 | Philips PSS110/17 MP3 Player
Playing songs
I've had the same problem, an it started when I formatted the player's flash memory to NTFS, an then realised it needed to be back in FAT(Win95) format for the mp3 player to play the songs. But after doing that, sometimes it'll mess up an the song number changes to 826, an the player completely freezes. I have to then take the battery out to restart it.
If anyone has schematics, or knows where I can track them down, I would be appreciative, for the RCA lyra M200
Feb 11, 2007 | RCA M200 (256 MB) MP3 Player
How to load songs in i-Bulldog IMP-90 (256 MB) MP3 Player
it is either one of the removable disks put the songs on to your desktop and drag them into the removable disk file in my computer soon enough you will have songs in you ibulldog.
Sep 24, 2006 | i-Bulldog IMP-90 MP3 Player
Mp3 problems
Make sure that the mp3's that you upload in the phone are in the correct folder, moreover make sure that the folder itself is named correctly otherwise the phone won't recognize it and might just ignore.
Jun 14, 2006 | Motorola Mobility V710
Trekstor Beat censo 73812 MP3 Player Logo
166 people viewed this question
Top Trekstor Audio Players & Recorders Experts
Richard Schabler
SmartAviator
SmartAviator
mac colar
Are you a Trekstor Audio Player and Recorder Expert? Answer questions, earn points and help others
