Question about Mitsubishi Televison & Video
Tv is locked by time needs passcode to watch - Mitsubishi Televison & Video
Lost code to unlock input, is there a by pass
Posted on Apr 22, 2010
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: v-chip reset do not know the 4 digit passcode and
If model number is correct WS55311 this set has a hidden menu (actually 3 of them) and one is the "Option" menu where you can do a hard reset of the set; it buts everything back to factory default.
It is done with a 4 digit code (I know depending on what model number is) and the original Mitsubishi remote has to be used for this.
Confirm actual model number and I will give that code to you.
sd tech
Posted on Nov 08, 2011
Mitsubishi wd62526 tv has a passcode on it that i dont know ;so is there a way to change it or reset it
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus. If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the TV remote control at the same time, when your passcode is requested. This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Press HOME to exit the menu.
Bypassing Front Button Lock If you have misplaced the remote control, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds
Aug 25, 2011 | Mitsubishi WD-62526 Projection TV
Need tv code, tv is locked
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
5
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Also note that forgotten the passcode of your Mitsubishi TV. You can make it alive without knowing the passcode. Please follow
V_Chip lock bypassing prodedure is as follows
You can view your locked TV, cancel the lock, or enter the V_chip lock menus.
This is done by pressing the number "9" and "QV" buttons on the remote TV control at the same time, when your passcode is requested. This process temporarily unlocks the TV.
When entering the V_Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
I hope this will help to solve the problem...
Aug 20, 2011 | Mitsubishi VS-60703 60" Rear Projection...
What is the code for my Mitsubishi WS-65511 rear projection TV remote control?
Hello
Lock menus.
you to enter a new passcode. Pressing HOME
at this time will cancel the entire passcode.
more than 8 seconds.
OK.
Feb 26, 2011 | Mitsubishi WS-65511 65" Rear Projection...
How do i get the v-chip lock code to unlock the parental lock from my Mitsubishi model code ws-55413
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV.
hope this helps
John.
Jan 11, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The power is not coming on, and when it does it says LOCKED, I don't have the original remote but I am using an RCA universal remote. How can I get my power back on??
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus. If you forget your passcode, you can view the locked TV without entering your passcode.This is done by pressing the number 9 and QV buttons on the TV remote control at the same time, when your passcode is requested.This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.Press HOME to exit the menu.
Jan 05, 2011 | Hitachi 51G500 51" Rear Projection...
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
password is requested. This process
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Forgot the password to tv
Good Day,
Bypassing the V-ChipLock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you forget your passcode, you can view the locked TV without entering your passcode. When your password is requested, press the number 9 and QV buttons on the remote TV control at the same time. This process temporarily unlocks the TV. When entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
When changing or deleting your passcode, you must use the remote control included with this TV. You cannot use any Mitsubishi remote control from another component or a "universal" remote.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi WD-62327 62" Rear Projection...
V chip locked up and dont have the code
seconds.
IMPORTANT
Cut along the dotted line and file
bypass instructions in a safe place for
future reference.
IMPORTANT
;ontrol included with this TV. You
use a Mitsubishi remote
_ontrol from another component
Sep 30, 2009 | Mitsubishi WS-65515 65" TV
FORGOTTEN FRONT PANEL KEYS LOCK PASSCODE
Try this Press Menu on TV and vol- down on remote handunit for 5 secs this should clear unknown Password.
Jan 04, 2009 | RCA R52WH73 Projection Television
V chip codes
LauriJo...
From the back of my Mitsubishi Owners Manual, Appendix A
"Bypassing the V-Chip Lock
If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the TV remote control at the same time when your passcode is requested. This process temporarily unlocks the TV.
When entering the V-Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode."
I hope that helps you.
Nov 02, 2008 | Mitsubishi WD-52526 LCD TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
