Question about Pioneer CDJ-1000MKII CD Player
The cd will loadin, but no information will display on the screen. the cue and play button will flash. when you press play no sound comes throgh
    Problem Solver:
  • 9 Answers
I don't recognise the fault but if you can get it to SW London I have a workshop there. [email protected]
Posted on Aug 21, 2008
SOURCE:
My gemini cdmp 6000 cue button is stuck it will not come out of cue. i need to hold cue button down in order for it to play
You need to take it to the shop and get the switch replaced. It shouldn't cost more than an hour's labor/bench charge and the cost of the switch. Depending on your market probably $75-100.
Jul 14, 2015 | Gemini Sound Products Gemini Cdmp-6000...
How to do transposition on Roland E-70 Intelligent Synthesizer from C to B
I don't know if you still need this information but here's a button by button guide that I've done. I've got an E-70 myself. Now if I can only find that **** internal battery that stores all my sounds I'd be laughing.
Press Menu (the button on the right underneath the light-up display), make sure the arrows are highlighted around the 'Param' setting and if not, turn the jog dial anti-clockwise to get the arrows there. Press Enter and then on next screen press Enter 5 times to see the Transpose display flash and use the jog dial to change from -11 semitones to +11 semitones and press Enter or backup to come out of this screen. Now, whenever you press the Transpose button (the grey button on the bottom right-5th button in from the right), the keyboard will automatically change. You can store different sounds in different keys, so for example I used to play Knocking On Heaven's Door and had this lovely riff when I played in G but it didn't sound the same if I played it in A so I transposed it to play and performed live in A while playing it in G. As long as you what presets you use for different songs, it's quite easy to get used to.
If you haven't had a response or sorted it out yet, I hope this helps.
Kind regards
Steve
Mar 11, 2012 | Music
Where is the button/knob set up to play single song verses continuos songs from a cd on Pioneer cdj mk..
The button you need is the Auto Cue button, which is to the left of the top display. Press and hold to turn auto cue off, which puts the player into continuous mode. This button is also the Time Mode button.
Hope this helps
Jaye
Sep 17, 2011 | Pioneer CDJ-1000 CD Player
When i press cue on my cdj 1000 mk3 it plays and i repeatedly press cue and it jus starts from the cue point and does not cue and then when i press pause it doesnt do anything so the song just keeps...
Your CDJ needs new Tactile switches. These sit under the big plastic knobs you press, and are actually what do the work when you press the button. Proably the most common failure on the CDJ range. Simple repair if you are competant at soldering. If not, take it to get serviced, they'll do it while you wait (if they're good!)
Aug 24, 2011 | Pioneer CDJ-1000 CD Player
My cue button on my cdj 1000 mk2 kept jamming so i got some foam cleaning stuff from a dj shop and sprayed it on the cue button now it started going mad skipping traks, playing in reverse. i think that the...
cue button sticking sounds like the button on the pcu board needs replaced, I would clean all the foam stuff of if possible, as for the screen not working sound like some of your wires have come unconnected easy fixed just plug them back on to the pcu board
Mar 28, 2010 | Pioneer CDJ-1000 CD Player
Cant cue up cd, it just starts playing when inserted
Hey,
no need to worry, there may be problem with micro switch.
Micro switch is that when u press cue there is a another micro switch just bottom of the cue button. I think micro switch needs to be replace and all done.
thx,
djajay
Feb 18, 2010 | Pioneer CDJ-800 Turntable
Queing up on cdj 200
In order to set a cue select th button IN/REALTIME CUE once you do that you an press the CUE button located next to the play buton.
Dec 28, 2008 | Pioneer CDJ-200 CD Player
I have a stanton-vestax cd-11 dual cd player, and was wondering how to get a cd to play on it. I put one in, turned the player on, pushed all the buttons and nothing happened. how does it work?
I have had one of these for many years: Switch it on, you must make sure the two transit screws at the back of each deck are fully unscrewed and loose, let the machine displays settle down, then insert a CD, then press the 'reset' button. There is a built-in delay of about 11 seconds before the deck begins to read. After this the machine should then display the first track number, and pressing the big red button will start play.
Pressing the 'reset' button again stops playback and the CD spins down, but if you leave the CD in there it will eventually re-index and cue up again. This feature is to enable fast, one-button CD changing and it works very well in practice, as the 11 second delay is enough time to take one CD out and get another in there before it tries to read it again.
To stop playback just press the 'reset' button (this is the most used button!) and take out the CD. After the delay, the machine will try to read a CD as normal, but display 'no CD' on the display. There is no stop button, as this unit was designed for continuous use in a club or disco.
Hope this helps. :)
Oct 18, 2008 | Audio Players & Recorders
CDJ 800MK2
the cue switch has to be cleaned by a technician. if that doesnt work. replace the cue switch.
Jul 15, 2007 | Pioneer CDJ-800MK2 Turntable
Pioneer CDJ-1000MKII CD Player Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
