Question about GE Microwave Ovens
My micro wave will not heat products. All other systems are functional.
  • GE Master
  • 9,086 Answers
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Posted on Aug 08, 2008
  • William Miller
    William Miller Aug 08, 2008
    Sorry, that post should have been a clarification request, not a solution:
MICRO DOES'NT HEAT
First, check to make sure that the door is closing and latching fully and that there is nothing jamming any of those mechanisms. There are safety devices that keep microwaves from turning on if they think the door is open/ajar.
If the door is fine and the rest of the functions (timer, etc.) are behaving, it's probably a busted magnetron. That's the part that actually emits the waves that do the heating. It's a part that can be replaced, but probably cheaper to get a new microwave.
Oct 02, 2012 | Sharp Microwave Ovens
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
I have LG MS3447GR Micro Wave Oven. It is functioning as before without heating. Please help?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,.,./ll
l
Mar 16, 2011 | LG LRM1260SW Microwave Oven
Everything comes on but micro-wave will not heat up products
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 18, 2011 | Samsung Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Micro wave stopped heating. All other features
Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
GE Over range microwave, JVM1660
This just happened to ours as well. Apparently the magnetron (device that creates radio waves that heat the food) is broken. I'm trying to pry the darn thing out of our kitchen now so I can replace the magnetron. Look for this part WB27X10489 on Google. I found it on ebay for $65. If it fixes the problem I'll post again.
Aug 18, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
