Model HLP6163WX / XAA DLP Samsung
I have sound but no picture. The bulb and ballista have been replaced and still have the same issue. Parts replaced:
Bulb part # BP96-00826A(P)
BP96-00690A Ballast Assembly
We were watching the TV and something popped, the picture went dim and it sounded like a piece of paper was caught in a fan. The TV was turned off, then on again and we got sound but no picture. Replaced the above parts and still no change.
  • wylie31 Aug 18, 2008
    I have a similar issue with mine At first I would get a picture that had static noise in it. By unplugging the unit and then plugging it back in would clear the problem. It would happen only like once every couple of months. Then today when I plugged it back in, I got sound and not picture. The unit would also cycle itself on and off.
    Before I spend money a Lamp I would like to make sure that this is the problem.
Sounds like the color wheel shattered. If you google it, you should find information about replacement parts and installation. I had to go through the same thing a couple years ago.
Posted on Nov 28, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Why does my DLP TV turn itself off
Try replacing that lamp door switch, this has been known to cause issues in some Samsung DLPs
Contact Samsung at 1-800-627-4368 for proper part#
Oct 21, 2014 | Samsung HLP5063WX/XAA
Samsung 61
If using a cable or sat box try a DVD etc when set cold, a box can cause lockup issues via signal.
Not a color wheel is correct, more likely a DMD which is rather pricy and almost as much as the entire light engine which comes with it.
Oct 12, 2012 | Samsung HLP6163W 61" Rear Projection...
I have a samsung hlp6163wx/xaa I replaced ballast and bulb. Color wheel sounds good but just a dark blue picture and perfect sound what could it be?
Some things to be aware of here--if the color wheel turns too slow set will shut down---if you hear a fan like or high pitched sound it is the wheel.
If a uniform blue and dark it is likely the DMD which is the box the wheel connects into and can be purchased by itself (forget that as for about 50 more than it costs you can buy the entire light engine that comes with it)
Bottom line: Likely a bad or damaged optical light engine.
A photo posted here or somewhere else with a URL location might tell me more.
further questions? Press the make a comment button on this page.
Mar 25, 2012 | Samsung HLP6163W 61" Rear Projection...
Once again my HLP6163W is not working. When it powers up there is a high pitch whine that sounds like it is a miniature jet engine powering down. The power button does not work, the set just powers up...
well I'm no expert but trying to fix one my self I'd say color wheel due to the noise issue... I have had repair places tel me the wheel and bulb and ballast are problems and if an old ballast is powering up a new bulb the old ballast will prob go out soon. sounds like the tv's are just junk I'm looking for parts so any ballast light or color wheel can be mailed to 25847 melba ave homeland ca 92548 and as I learn more with them good or bad parts I'll surly post it for the good of all so we can keep the land fills empty of the stuff.
Thanks for reading model hlp6163wx/xaa only please.
Aug 17, 2010 | Samsung HLP6163W 61" Rear Projection...
I have been trying to fix my hlp6163wx/xaa I replace the light bulb and ballast I have no sound or picture what else could it be!?
could be the colorwheel. listen right after the power button is press you should hear a slight wind up noise coming from the rear of the tv. if you dont hear that the colorwheel may be bad
Jan 30, 2010 | Samsung HLP6163W 61" Rear Projection...
Problem with the White vertical lines on Samsung 50 in DLP
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Nov 05, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Televison & Video Logo
803 people viewed this question
Top Televison & Video Experts
