I can't find the Serial number on the inside of the printer.
To find the serial number on the MP830, open up the printer by lifting up on on the front shelf (the one with all the buttons and display). It should tilt back and and be held up on two pistons, one on each side.
There is a large cutout inside the center of the printer where you can see a folded over grey ribbon cable. If you look behind the ribbon cable on the right side, you will find the serial number.
Happy hunting.
Posted on Aug 15, 2010
It is either on the bottom metal plate inside under your printer head, or on the outside on the right of the printer! Hope that helps!
Posted on Oct 14, 2008
I've just bought a Canon Pixma MP220 from Argos in the UK and I too had the same problem. I wanted to register with the Canon iMAGE Gateway, as suggested during the installation procedure, but the registration form requires that the correct form of Serial Number is entered. The form's help link directs to https://www.cig.canon-europe.com/ce/en_GB/how_to_find_serial.html where it is stated that you should open the top cover and look for a sticker that indicates the serial number and that 'The 9 alphanumeric characters on the sticker is the serial number'. As I could find no such sticker, I checked the box that the printer came in and found a label on which there was an entry for 'Body No.: No de serie: Gehause Nr.: No de cuerpo:' so I tried the number printed there and that worked OK.
Posted on Sep 06, 2008
Can not find the serial number
In the Canon PIXMA MP560 printer the serial number can be found inside the printer. Lift the lid as if you were going to change the ink cartridge. When the cartridge slides to the left, you will be able to see a small white sticker inside the track with the serial number printed on it
Thanks,
E-ware
Jul 26, 2011 | Canon MP560 All-In-One InkJet Printer
Where is the model serial number on the Canon MX882
Issue: Where is the serial number located?
Solution: Locate the serial number MX882
Locate the Serial Number The serial number of the MX882 is located inside the printer, as shown below.
  1. With the printer powered on, open the Paper Output Tray (A).
    The above illustration shows a PIXMA MX870.
  2. Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
  3. Wait until the print head carriage moves to the ink tank replacement position.
  4. To the right of the print head carriage, inside the printer, is a white sticker that is attached to a metal plate. The serial number is located on the white sticker. Please see the illustration below.
    The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
May 09, 2011 | Canon Office Equipment & Supplies
Where can i find the serial mumber on my canon pixma mp495 printer tried all on bottom
PIXMA Printers and All-In-Ones
The serial number is located inside your PIXMA printer. To find it, open the printer lid as if you were to access the cartridges tray: the serial number is printed on a white sticker. Be careful to not confuse this number with the power supply serial number that can be found on the bottom of your printer.
Hope it helps.
Apr 26, 2011 | Canon PIXMA MP495 InkJet Printer
Where is the serial number on a Canon PIXMA MP530 multifunction printer?
The serial number of the PIXMA MP530 is located inside the printer, as shown below.
  1. Lift the Scanning Unit (Printer Cover) until it locks into place.
  2. When the printer is powered on and the Scanning Unit is lifted, the Paper Output Tray will open automatically. If the Paper Output Tray does not open after several seconds, press the Open button to open the tray manually.
  3. Open the Inner Cover.
    The serial number is attached to the back wall inside the printer.
    It starts with four letters (AAGA) and ends with five numbers. Example: AAGA01234
Mar 04, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Where is the serial number on my pixma mp560 printer?
Good day.
It is normal to locate the serial number at the back of the printer but in the case pf MP560 printer, the serial number is located inside the printer. Open or lift the LID just like when you are changing Ink Cartridge. The cartridge assembly slides to the left, there you will see the white sticker inside the track with the serial number.
Just let me know if you still need some help.
Good luck.
Tedmac
Oct 01, 2010 | Canon MP560 All-In-One InkJet Printer
Where can I find the serial number on my canon mp560
For Canon PIXMA MP560 printer the serial number is INSIDE the printer. Lift the lid as if you were going to change the ink cartridge. When the cartridge slides to the left, you will be able to see a small white sticker inside the track with the serial number printed on it.
Feb 11, 2010 | Canon MP560 All-In-One InkJet Printer
I can`t find the serial number on my printer its a canon pixma mp190.
located inside the printer. Only the model number is visible outside.
Oct 01, 2009 | Canon PIXMA MP190 All-In-One InkJet...
I have a pixma mp480 printer and i can't find the serial number
Locate the Serial Number The serial number of the MX310 is located inside the printer, as shown below.
  1. Lift the Scanning Unit (Printer Cover) with both hands, and pull the Scanning Unit Support down into place. The FINE Cartridge Holder automatically moves to the left.
  2. The serial number is attached to the back wall inside the printer.
    It starts with four letters (AAVH) and ends with five numbers. Example: AAVH01234
Aug 05, 2009 | Canon PIXMA MX310 All-In-One Printer
About serial key
Details Issue: Where is the serial number located?
Solution: Locate the serial number MP150
topFrame=findTop(this); Locate the Serial Number The serial number of the PIXMA MP150 is located inside the printer, as shown below.
  1. With the printer powered on, lift the scanning unit and pull the scanning unit support down into place.
    It starts with four letters (JCBA, JCBB, JCBC or JCBD) and ends with five numbers. Example: JCBA01234, etc.
.footergray { font-family: Arial,Helvetica,sans-serif; font-size: 9px; color: black; text-decoration: none; font-weight: bolder; } .footerblack { font-family: Arial,Helvetica,sans-serif; font-size: 9px; color: black; text-decoration: underline; font-weight: bolder; } © 2008 Canon U.S.A., Inc. All rights reserved. Duplication in whole or in part without permission is prohibited.
Jan 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Pixma530 printer where inside is thhe serial number?
Go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
and type in serial number. The first result shows you exact instructions for finding the number. This assumes that your model is a Pixma MP530 - the only 530 in the Pixma line that I could find. The content of that page appears below (illustrations will likely not appear properly):
Locate the Serial Number The serial number of the PIXMA MP530 is located inside the printer, as shown below.
Please post back if you need additional assistance, otherwise thank you for using and rating FixYa!
Jun 02, 2008 | Computers & Internet
495 people viewed this question
jasbo
jasbo
