Question about Biostar Computers & Internet
I am attempting to isntall a new biostar am2 socket micro board with a sempron cpu. I get everything connected, but when I turn on the power from the front panel, the fans will spin for a moment, then die and pressing the power button again will not do anything. If I turn off power from the back, then wait 30 secs, then turn it on then try the front switch it again spins the fans then dies. I have had this happen with two cpus (Athlon and now the sempron). I am not sure why this is happening but before I buy another item I'd like to see if I can get it to work.
  • bucc5062 Aug 08, 2008
    i took the cpu out, the panel switch turned the system on. I had to use the back switch to turn it off.
    I put the cpu back in, unplugged everything but power, and back to same action. I pulled memory and same on off result. I am not certain what you mean by two pins. There is a red jumper with two out of three covered. Anything else I can try? The biostar M800 motherboard should work with the sempron cpu chip.
    Sergeant:
  • 395 Answers
Take out CPU and switch it on - do you get the same behaviour?
If so then CPU is probably wrong sort - check model of mainboard and CPU.
If behaviour is differnt then fit CPU and remove ram - if it beeps then CPU is working. Replace RAM and disconnect ALL other devices (hard disk, CD, front panel connect cable, reset button) just leave fans and power plugged in. now short out two pins for power on switch and see if it starts up.
Posted on Aug 08, 2008
  • Steve Si
    Steve Si Aug 08, 2008
    Hi
    There should be a front panel header which connects to your power button, hard disk led, power led ,etc.
    disconnect all of these.
    Then you can switch on the mainboard by shorting out the two links where the power button used to connect to.
    This is quite safe as these pins are only low voltage - low current.
    If you have mistakenly connected the reset pins to the LED, then the board will be in permanent reset when you switch it on, by removing all cables, you can make sure you have not misconnected anything.
    If it did not beep when you removed ram then the CPU is not running :-(
Can a Biostar NF61S MICRO AM2 SE (NF61MICROAM2SE) Motherboard run a AMD dual core X2 7750 2.7
Hello look here for the cpu list:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=23#cpu
Try also to look in the manual.
I think it will fit, but you probably have to upgrade the bios, to support the new cpu.
Good luck
Dec 19, 2012 | Biostar NF61S MICRO AM2 SE...
I have bought 2 Biostar N68S motherboards for HTPC builds. Both of them have the same CPU and RAM. Neither of them will show any VGA output, despite being hooked up to different screens. The other...
The motherboard has a AM2+/AM3 socket, and the processor is AM2, while there is some compatibility between AM2+ and AM2 sockets, it is not guaranteed, so this could very likely be your issue.
Jul 23, 2011 | Biostar N68S NVIDIA MCP68S Socket AM2+/AM2...
How to enable sata connections Nothing in the BIOS allows for SATA on or off
There is no sata , you can see in bios IDE coniguration, in that menu you can change it
May 30, 2011 | Biostar K8M800 Micro AM2 VIA K8M800 uATX...
I just finished building a PC using motherboard Biostar N68S, but it won't power up. When I push the power button, it only works for 1 second. Everything is connected. What seems to be the problem?
Try to verify these :
1- Check that all perepherals are connected correctly (HDD, Drives...)
2- Check taht the motherboard support the CPU you are using.
2- Check that the RAM is correctly inserted (use an other connection slot)
3- Check that the CPU is correctly inseted and that the FAN is correctly placed
4- Check all USB port, may be there is a short circuit.
5- Check your AC Power.
Good Luck.
Apr 01, 2011 | Biostar N68S NVIDIA MCP68S Socket AM2+/AM2...
Matharbord drivars
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=209
Nov 18, 2010 | Biostar K8M800 Micro AM2 VIA K8M800 uATX...
I have a biostar board A740G M2L, I want to know if the sempron processor will work?
Hello
A740G M2L+
Click here this is the specification sheet for your Mainboard.
Yes, Sempron AM2/AM3 processor will work.
Best of luck building your PC it is very exciting.
Oct 24, 2010 | AMD Computers & Internet
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
Nothing powers up
Check your power supply connections
Sounds like you may have missed the P 4 connection near the CPU socket.
Hope this helps you please rate...
Thank you
Aug 22, 2009 | Biostar K8M800 Micro AM2 Motherboard
I want to know where i can find the CPU support list of Biostar band TFORCE TF560 A2+ motherboard
from biostars website
Socket AM2+/AM2
Supports AMD Athlon 64 X2/64/FX/Sempron Processors
Hyper Transport Technology up to 2G
Supports AMD Cool'nQuiet Technology
website link
http://www.biostar-usa.com/mbdetails.asp?model=TFORCE%20TF560%20A2%20+
Nov 25, 2008 | Biostar MB BIOSTAR TForce TF7050-M2 AM2...
Computers & Internet Logo
53 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
