Question about Canon Pixma iP4500 InkJet Printer
Canon iP4500 colour management
When working through a colour management workflow with this printer and setting Colour Handling to Photoshop Manages Colours, the instruction is to cancel the printer's colour management with the 'no colour adjustment' option, but I cannot locate this any where. Can you help please?
  • mick_weed Aug 08, 2008
    Sorry this doesn't work - I've tried all the obvious solutions but still answer.
    Thanks this is looking better but..
    I use Fujifolm Premium glossy paper and have just obtained an ICC profile - monitor set up with Spyder 2. Results are reasonable but sgill some disparity between monitor and printed colours and I wonder whether this is because I have note been able to cancel the rpinter colour management. Hence m,y original question. Regards
    Genius:
  • 1,269 Answers
Try this setting. This might be different but try to point some similar preferences and steps then you can give it a try.
Open Control Panel (I'm assuming that the OS is Windows XP) click on Printers and Faxes.
Right click the Canon iP4500
Click Properties in the drop down menu.
Click on the tab Color Management
There should be a list of color profiles if the drivers were installed properly.
They are-
(Generic)
(Matte Photo Paper)
(Photo Paper Pro)
(Photo Paper Pro Matte)
(Photo Paper Plus Glossy)
The last profile is the one you want. Just above you will see the choice of "Automatic" or "Manual". Click on Manual and this force the printer to use the highlighted profile for all printing jobs.
Now click on DEFAULT.
Go back to the main Properties page and click on the General tab.
Near the bottom you will see "Printing Preferences"
click on that.
You should now be in a Canon ip4500 Printing preferences window.
Look for Print Quality and click "Manual"
Click on "Set"
Click on "Diffusion" and just above that there is a slider that should be all the way to the right.
Click "OK" to save the settings.
Now just below you will see "Color Settings"
Click "Custom" and then "Set"
Everyone sees colors a little different but the following settings print a photo that folks I show them too really like the balance of.
Cyan 4
Magenta -12
Yellow 0
Black 0
Intensity Slider in the middle
Enable ICM not checked (disabled)
Print Type set to Photo (you might want to try the other settings here to see how the prints look to your eyes)
Brightness Normal
Click OK to save settings and return to the Main Menu.
If you now go under the Profiles tab you should see you new profile there.
You can give it a special name like "Canon Excellent Profile Settings" Canon iP4500 colour management - clip_image001.gifor some other easy to remember name. This is the profile you want to use when you print a photo.
That is it...simple eh?
Now the other important part is in PhotoShop/PS Elements. Open the program and then open any old photo.
Under File, scroll down to Print Preview and click
If not open, click on "Show More Options"
Bring up "Color Management" in the box just below the "Show More Options"
For "Source Space" click ""Document"
This setting depend on the profile you shoot in, either Adobe RGB or sRGB. You choose the one you use.
Below that there is a setting for "Print Space"
You want to match that to your source, whether Adobe RGB or sRGB.
For the "Intent" letting I choose Perceptual.
Then click "Use Black Point Compensation" and that is it. Ready to print
Posted on Aug 08, 2008
    Master:
  • 521 Answers
Right click the printer icon and then goto printer properties and change the colour and paper settings as per your requirements.
  • tech expert12 Aug 14, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
  • Canon Master
  • 6,487 Answers
Try this one:
In Photoshop, go to View>Proof Setup>Custom and select the ICC profile for the printer and paper that you will be using.
Canon iP4500 SG* is for printing with Canon Everyday Glossy Photo Paper (GP-501/401) on your printer.
Canon iP4500 SP1 is for printing with Canon Plus Glossy Photo Paper (PP-101) on your printer.
Canon iP4500 PR* is for printing with Canon Photo Paper Pro on your printer.
Canon iP4500 MP* is for printing with Canon Matte Photo Paper on your printer.
Select a rendering intent (i.e. Perceptual, Relative Colorimetric, Saturation, Absolute Colorimetric). I normally use either Perceptual or Relative Colorimetric on my Canon printers.
You might want to check black point compensation.
The display will now show you how the image is supposed to look once printed.
Edit the image based on the softproof.
Afterwards, go to Print With Preview.
Select the same color profile and rendering intent that you used for softproofing.
Choose Let Photoshop Determine the Colors.
Hit Print. Select the paper that you will be printing on. Go to Color Options. Select none for Color Correction.
Hit Print again.
Hope that helps.......
  • Mark Gil
    Mark Gil Aug 08, 2008
    Try to do again the procedure one more time to check fi you will have a better results...
    Good luck........
    Genius:
  • 1,011 Answers
Dear Sir/madam,
click this link How to set this option....
http://www.gballard.net/psd/printing_epson_photoshop_cs3.html
thanks
good luck
    Brigadier General:
  • Canon Master
  • 3,614 Answers
Go to control panel>> select prinnter and faxes>> there right click the icon of your printer and click properties...
Why is the colour in my photographs not printing as they are in my laptop I have added new inks and cleaned the printing heads
Anonymous, there's a whole science of "color management" that you've invoked. First, what you're seeing is truly caused by lack of "calibration" in any stage of your workflow.
Your camera takes pictures, and whatever colors it sees are what it sees.
Your monitor shows you colors, but there's no standard calibration involved.
Your printer prints colors, but it too isn't calibrated to any standard.\
Assume for a minute that your monitor is set up to be a little too dark. You edit the pictures, and lighten them up so they look ok on screen. Now, when you print the picture, it's too light.
I've had similar issues, and have ended up purchasing a monitor calibration tool (Color Munki Smile) to calibrate my monitor, software "Profile Prism" to calibrate my printer, and now the prints I get look almost exactly like what I see on screen...
Sep 11, 2014 | Canon Pixma iP4500 InkJet Printer
My Canon Pro9000 MarkII prints photos with a red tint
You probably haven't calibrated your monitor to show the correct colours, so in whatever photo programme you're using, you're setting the red tones too high. Test this by first not calibrating your monitor, but turning down all the red tone until it looks washed out. Print this and see if it's better. If so, set your monitor to a cooler colour temperature. If the result is no better, check your print dialogue settings to make sure you are using an appropriate colour profile. And, for example, if you're using Photoshop, tick 'let Photoshop manage colours' in the advanced profile settings box. Hope this helps. I doubt there's anything wrong with the printer.
Dec 29, 2012 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Canon pixma ip3600 blue colour cast
I don't get true B&W but only 1/2 a Gnats knacker off it, if you send for a test print from say Ilford you'll notice that it's not B&W but a warm tone very slightly sepia.
I use cheapo inks bought on eBay so none of the settings in software are of any use. I disable any attempt by the software to influence the printer and do the same in the printer settings window. I then alter the colours using the sliders in the Manual section of the colour/intensity to the colour that I see on my screen and save the setting in the profiles section.
I use the iP3600 and have found it very good indeed, after lots of experiments I've settled on a sepia tone reminiscent of Sodium Sulphide but without the nasty smell.
Jim
Jun 23, 2012 | Office Equipment & Supplies
No preview on LiDE70 scanner
Which Operating system you are using.Priewe
CanoScan ScanGear 12.0 – manages workflows in either ‘Simple’ or ‘Advanced’ modes – in the latter floating palettes allow fine adjustment of Histogram, Brightness & Contrast, Tone Curve and Gamma. New features include: Gutter Shadow Correction for eliminating the spine shadow when scanning books; Saturation/Colour Balance; an Enlarge Preview Area function for even more precise control of grey balance and highlight shadow correction; and improved Dust and Scratch Removal.
Dec 30, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Epson 1400, Mac computer, paper profile all set up. Using CS4, I can't see how to disable colour management in the printer set-up window. If I choose photoshop in colour handling, it doesn't print...
Solved by a friend who told me that i needed an up-to date driver for my brand new Mac - why hadn't it been loaded a long time ago - this seems to have been a problem for quite a time, A vital bit of the printer menu was missing. Please get the Apple Mac to use the latest driver for this machine.
cardy
Nov 10, 2009 | Epson Stylus Photo 1400 Printer
Colour management MP500
The printer profiles are in the printer properties tab either in the control panel under printing preferences, or in the dialog box that pops up when you press print, under advanced options and preferences.
Jun 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Using the IP5000 and Canon Glossy Photo Paper am
Every time I have had problem have had to replace ink.
Sep 05, 2017 | Canon PIXMA iP5000 InkJet Photo Printer
Canon Pixma iP4500 InkJet Printer Logo
831 people viewed this question
old marine
old marine
