Bausch and Lomb Tall Master 68-4020 Tripod Logo
Kidron Robertson Posted on Apr 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a B&L Masters tripod model #68-4020. I also have a Zoom Spotting Scope model#78-1600. The scope has the plastic mounting bracket but the tripod doesn't have a connection that will allow the scope to be connected. The tripod has a plastic bracket that will allow a camera to be connected to it. Can you tell me where I can find a bracket to go on top of the tripod that fits the scope? I have already tried Bushnell products,Bausch and Lombe,and Optics Planet and local camera stores with no success Thank you
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Apr 18, 2011
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801637
Points
33142
Hello kidron. take all of the components into a good camera shop and show them what you wish to do. I am sure they will have access to the components you need. Joe
Which is the good spotting scope for higher amount of light?
Bushnell Trophy Xtreme Spotting Scope
Overview
Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Specifications
  • Brand:Bushnell
  • Viewing Configuration:Straight
  • Magnification:16-48X
  • Power Variability:Variable
  • Objective Diameter:50 mm
  • Close Focus Distance:25 feet
  • Length:13 inches
  • Weight:31.4 ounces
  • Field of View:125-60 feet/1000 yards
  • Eye Relief/Exit Pupil:16 mm/ 3.1-1 mm
  • Optics Coatings:Fully Multi-Coated
  • Glass:BaK-4
  • Focus System:Focus Knob/Single Focus
Feature Analysis
  • Porro Prism Lens
    Though many optics producers keep on trying to transform roof prism lens, Porro prism lenses are more affordable and light-efficient. These Porro prism lenses can display images with better contrast than roof prism variations. This is how Bushnell Spotting Scope is more reliable and affordable for its high-quality performance.
  • 20-60×65 Zoom Magnification
    The wide range of magnification allows user flexibility for long-range view finding. You can observe details with 65x zoom for long range objects. But, you can still enjoy an increased field of view with 20x zoom. This is used when separating the areas for closer zoom viewing later on.
  • 65x Lens Light-Gathering Capability
    This advanced magnification lenses can light gather at long distances. The Bushnell Trophy 20-60x 65mm Waterproof Spotting Scope resolves this issue by designing 65x zoom lens in a way that brings 17% more light than most high-zoom lenses.
    If you fully read Bushnell Trophy Xtreme Spotting Scope Review, it will support you how to setting zoom for longer distances images.
  • Waterproof Construction
    When you go out in nature, this waterproof construction anticipates you about rain or even snow. It is pretty obvious that any liquid that leaks into your scope will detract from the overall image. But many people do not consider the effects of concentration on the inside of the lens.
    This spotting scope is actually water and fog proof not only for outside moisture but also prevents lens fogging from risky temperatures.
  • Fully Multi-Coated Optics
    The multi-coated lenses prevent any reflections in the glass that can delay your view. The sunlight at certain angles can cause reflections from water or wet surfaces that prevent the clear view of the images. That is why; Bushnell uses multi-coated lenses to remove any kind of reflection.
  • Well-designed Equipment
    The tripod often needs to hide from animals, and the scope cases also need to protect their insides from both jostling and the outside elements. The Bushnell Trophy XLT comes with both a hard-side case and a soft side case. The hard side case protects you from outside damage and a soft-side case protect you from a bumpy road when you are riding.
Mar 18, 2018 • The Optics
tip
How To Use A Spotting Scope For Shooting
If you practice hunting and shooting, a spotting scope is one of the best instruments that you need to have to provide you with a clear view when you are aiming at your target. Before we get started on how to use a spotting scope for shooting, it is great if you know what exactly a spotting scope is.
Precisely, a spotting scope is a small device that is used for many outdoor activities to magnify and help you watch images and objects closely. Before purchasing the best spotting scope for shooting, you need to know a few things that will help you use it well in your shooting career. Here are some things that you need to know when using a spotting scope for shooting.
Comfortable Position Is Key
If you want to get the best performance from your spotting scope, ensure that you position yourself in a comfortable place. You know when you are using a spotting scope you will be holding it for long so it is very crucial to find a comfortable place that you can sit or lay down depending on what you find best. Make sure you find a comfortable place and learn more about the specifications of the area which should be the point of targeted area.
Attach Your Scope To A Tripod
Sometimes holding your scope with your hands can compromise the quality of images that you get because of shaking and fatigue. If you want to achieve a clear and accurate view, get a tripod and attach to your scope. This means that your scope will be very stable because there are minimal movements so you end up getting very accurate results. When you are using a tripod, the chances of missing your target are very minimal.
Adjusting The Magnification
You should also adjust the magnification of your spotting scope to a level that you like. Spotting scopes are designed differently so you need to know how to adjust magnification and the lens layout of your scope. For the most accurate results, it is great if you read the instruction given about the magnification levels and how to adjust.
In some spotting scopes, you need to use the lens knob so that you can zoom in and out of the magnification. In other scopes, you need to use the small zoom in and zoom round trigger on the point of the eyepiece.
View Target Area And Adjust Magnification
When you are using spotting scopes, it is not advisable to go with the magnification first because you might not get the right results. The best thing that you can do is to view the target area first and then adjust the magnification effectively.
Reset Focus In A New Area Always
This is very important because a sudden highly magnified glass can cause problems to your eyes. This means you can feel uneasy when you are watching your target longer. This results because of watching at a very high magnification glass for a prolonged period. You can overcome the problem by reducing the effect of the magnify glass on your eyes.
Beating The Sun
If you want to become a spotting scope pro, you must learn how to beat the sun. You need to know how to deal with the frustrating heat waves because they quickly distort your view and it becomes difficult to grass. The best way in which you can beat the sun is to zoom out. Zoom out to a lower power setting and you will enjoy heat-wave glassing hours. You should wait for passing cloud because they reduce the heat wave and give you the chance to zoom back in your target.
Final Words
Buying the best spotting scope for shooting is not enough. You also need to learn how to use it so that you can get clear and bright images all the time. This will help you gain accuracy when you are shooting so no more missed shots. If you learn these tips, you will not experience any problem when you are hunting or shooting. Knowing how to use your scope is the only way in which you will get most out of it when shooting. Best Spotting Scope to buy in 2017 Buying Guide Reviews
on Jul 19, 2017 • Miscellaneous
1helpful
Which is the best spotting scope under $ 250?
Mar 17, 2018 • Firearms
1helpful
What are the features of Spotting scope?
Landove Prism Spotting Scope Review Best Spotting Scope In 2018
An overview of Landove Prism Spotting Scope
Everybody cherishes a lovely vacation. Recreational activities like hunting, hiking, wildlife or bird watching refresh our soul. In this case, enjoying a beautiful scenery spotting scope becomes a necessity to have a wonderful sight and captivate such sight in our mobile screens and cameras.
Most of the spotting scope provides this sort of view, but Landove Prism Spotting Scope is unique. We face trouble when we have to carry too many devices and skip perfect glimpse managing those devices. But Landove Prism Spotting Scope is different because it has a space to adjust our mobile phones or camera of such size.
The Landove Spotting Scope review holds the scope's other benefits which are described below.
Specifications
  • 20×60x zoom eyepiece
  • Prism: Bak4
  • Objective lens diameter: 80mm
  • Eyepiece diameter: 20mm
  • F.O.V angle: 1.58 degree-0.91 degree
  • F.O.V (feet /1000yds): 82.9ft-48ft
  • F.O.V (m/1000m): 27.6m-16m
Feature Analysis
Superior magnificationLandove Prism Spotting Scope review states one of its best features which is a 20x60c zoom. With a higher magnification like this, you can click or picture video clips of scenes located very far. But that would not ruin the quality rather it will be clicked with much clarity.
WaterproofWeather can be a great hassle sometimes and mess up our entire plan. But this spotting scope will not let that happen. Landove prism spotting scope is waterproof and allows apprehending the beauty of nature during rain too.
Dynamic lensThe spotting scope has superb focusing system because of its dynamic lens. The lens allows you to have a clear aim and focus on the target.
Fully multicoated opticsThis Landove Prism Spotting Scope review has already stated about the clarity given by the spotting scope. It has a fully multicoated 65mm green film objective lens, superior quality prism, and eyepiece. These specialties let you have a brighter and fresh picture.
Cell phone adapterLandove spotting scope digi-scoping adapter which can adjust your phone to the scope. This adapter helps you to take picture or video clips of the heavenly nature and charming animals without any trouble. For this reason, people all around the world prefer this spotting scope so much.
Standard coating and materialsThe spotting scope is a very light material, but this one is strong enough to be used often. It has a fine design with durability, metal framework and contains rubber armor. The tripod can be attached to the spotting scope which is portable and durable too.
Pros & Cons
Pros
  • Cell Phone Adapter
  • High-quality lens
  • Portable
  • Affordable
  • Easy to use
Cons
  • The Camera lens arrangement sometimes causes barrier for the scope eyepiece.
Final Verdict
Nature always amazes us. Travelling and sightseeing are also required in order to explore the beauty of nature. Spotting scope has become an additional requirement with this. Landove Prism Spotting scope review has remarked all the specialties and a disadvantage of this scope. But this disadvantage can be easily ignored in exchange for such crystal-clear vision.
Landove Prism Spotting Scope has become a top choice for people worldwide because it lessens the difficulties of carrying more than one device. Its features will always increase your excitement and add liveliness to your trip, bird watching or archery.
We can conclude our review by saying this scope is worth purchasing and a great deal undoubtedly. Hopefully, this landove Prism Spotting Scope Review will guide you through the buying process.
Mar 12, 2018 • The Optics
GSI Spotting Scope Manual?,"T" camera adapter? availability?
have a look on ebay, type in t2 under (camera > telescope-binoculars) look for a t-mount similar to the picture added. these t-mounts allow for the focus to be adjusted and the eye piece to remain in place. hope this helps87ec49f6-6cfc-43d9-b599-49b2897eaa42.jpg
I need to purchase screw that attaches scope to window mount on a 78-4405
The mount has a 1/4-20 screw that fits most camera equipment. If you have the scope (spotting scope) it should have that hole in the bottom of the mounting ring. If the screw is missing from the window mount then most 1/4-20 tripod screws will work or you may substitute a cap screw and flat washer, to work with an Allen wrench for tightening.
I have a WO IBIS 80 APO Spotting Scope. How do use it with other 1 1/4" eyepieces? The packaged zoom eyepiece seems to have a threaded attachment to the scope.
sounds like it was designed to use only the eyepiece that came with it. here is an idea...mount the scope on a tripod with no eyepiece in it...now take an 1 1/4" eyepice and place against the scope where you would put the eyepiece ..try to focus..if you cant, then slowly bring the eyepiece away from the scope till you see a sharp image..im sure a machine shop can make a sleeve to screw into your scope and hold 1 1/4" at that point.any questions i can answer call me [email protected] 5088331232
Nov 29, 2008 • Optics
SWIFT MARK II, MODEL 841 SPOTTING SCOPE BASE
Hi, I would contact Swift directly on this number: For ordering parts or warranty repair information, please contact Swift Customer Service at 800-523-4544. You can get other contact information and dealer locations on their website: http://www.swift-optics.com/support/faq/dealer The 'scope is mounted on a standard camera tripod thread so you can always check your local camera dealer. Please update the question & let us know if the information given was useful to you - Good Luck!
Top Bausch and Lomb Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Bausch and Lomb Photography Expert? Answer questions, earn points and help others
