Question about Logitech Cordless Internet Handset Phone
Wont stop searching for skype
(accidnelty asked this for the wrong item)
I am having an issue with the phone. When it starts up it goes through but once it gets to searching for skype it freezes up. We have uninstalled both skype and the phone but it still wont work. Thanks for the help
  • Anonymous Sep 05, 2008
    I have the same problem. Any help will be appreciated.
    Using:
    Vista Ultimate
    Skype v3.8.0.154
    Thx
    KP.
  • 3 Answers
I just fixed this issue.
1) Unistall both Skype and the Logitech software
2)Start Windows in Clean Boot Mode (http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=6674&p_created=1178609978&p_sid=VD3JP5dj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NDUsNDUmcF9wcm9kcz0wJnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jbGVhbiBib290&p_li=&p_topview=1)
3) Re-Install the software (ensure the Logitech software is for Vista)
4) Restart in normal boot mode.
This worked for me and connection is working. The only thing that isn't working is the phone is ringing when I call in using SkypeIn...
Posted on Sep 05, 2008
SOURCE:
For my fz16 yamaha i wud like to ask what cud b the posible problem here is the symptoms.. when in cold start the engine runs fine but when it goes hoter the engine wont idle
Hi, Al-bar and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have nice a day.
http://fullmanuals.com/search/?q=Yamaha+FZ16
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 08, 2015 | Yamaha FZ 600 Motorcycles
Skype won't ring on my galaxy ace 2
make sure your notifications are turned on in your skype settings and if they are make sure to check your phone settings as well
Feb 18, 2014 | Samsung Galaxy Ace Android Smartphone
MY DUALPHONE IS REG. WITH BASE STATION WHEN COMEING TO SIGN IN PART IT WONT RECONISE MY SKYPE NAME OR PASSWORD WHICH IS RIGHT PERFECTLY JUST KEEPS SEARCHING ONLY SAYS SIGNING IN TILL I STOP IT
Hi
I had the same problem when i first installed this, I found that username and password have to ONLY contain lowercase characters or it wont register or login to skype correctly
I hope this helps
Mar 07, 2011 | RTX DUALphone 3088
Why won't the green light for my camera go off. its always on and it wont let me use skype or photobooth!!
You need to check and see if any other application are using the isight. Go toApplications > Utilities > Activity Monitor
at the right there is a drop down box select "All Processes" search for any process that might be using the isight camera. select the process and click the red stop sign to "quit processe"
If that doesn't work try to restart the computer.
If the issue still persist go to Apple Menu (Apple icon, top left) > System Preferences > Accounts select the account that you are login at click the Login Items tab here is all the applications that start automatically when you login to this account. select the application that might be giving you the problem (ie skype) click the minus icon at the bottom to remove it.
Oct 25, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Youbreplied to e buy i will like to ask you how to remove auto sign ip from a mac laptop...the application i have on the laptop is skypefor mac laptop not window xp...please advice asap.
You have to sign out, and disable that option at Skype / Preferences / General. If you also don't want to have Skype automatically starting when you start your Mac then go to System Preferences/accounts/Login items, then delete Skype from the login items.
Oct 17, 2010 | Computers & Internet
When using a usb design and very occasionally when using a built in design the screen switches off without warning and the machine either judders to a halt or just goes on madly stitching in the same place...
This is probably one of those dreaded instances of a problem that the technician cant reproduce. It sounds like a main board issue that is not consistent and therefore the tech doesnt know which direction to take. If you purchased the machine at a dealer store you normally have a 1 year free service period and the part should be a warranty item. Ask them for help in resolving the issue.
Jun 19, 2010 | Janome 200E Computerized Sewing Machine
Logitech webcam that doesn't want to work with skype now
I experienced the same symptom (Skype would load with WinXP but NOT recoginize my HP Elite webcam and its ArcSoft drivers). I noticed that I could 'cure' the problem by manually stopping Skype after WinXP loaded (right click on the Skype task and Quit). Then, when Skype has stopped running and Windows is still up, manually restart Skype.
It appeared that the problem was one of task startup order. My system runs McAfee's Secuity Suite and that takes a FULL 2.5 minutes to activate after the initial Windows desktop appears.
So, for grins, I searched for a freeware startup manager (used WinPatrol) and installed it. I assigned the Skype startup task to the delayed column and set the delay to 2.5 minutes so Skype wouldn't try to load before the McAfee firewall was up and running. That cured the problem of Skype starting without seeing a webcam!
I played with the delay and found even WinPatrol's minimum delay (10-30 seconds) also provided relief...
Aug 11, 2009 | Computers & Internet
Binatone s1085 skype connection
uploaded driver for this, download it here:
http://www.2shared.com/file/7862486/1e6390e/BinatoneInternetPhone.html
or
http://www.megaupload.com/?d=60BZI5Q5
Unzip it, its a .exe file, that runs direct... (no installation)
either launch it manually
or put it in startmenu>allprograms>startup
other ways to launch files on start up - do a general google search
Mar 02, 2008 | Lands Phones
Dvd burner problem
This problem sounds to lie in the software. May I suggest trying a different burning program. Also you may want to search NERO's documentation on this issue.
Nov 02, 2007 | Pioneer DVR 105 DVD-RW Burner
Logitech Cordless Internet Handset Phone Logo
383 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
