Question about Zanussi WJS1265W Front Load Washer/Dryer
I have a zanussi zwd12270w front loading washer and dryer. The start/pause button continues to flash, irrespective of the program you select. The machine does not start.
  • 41 Answers
It sounds like you may have a problem with the door interlock !
Has your machine displayed any error codes ?
regards
Ian
Posted on Apr 17, 2011
  • Dave Sep 14, 2013
    No error codes
SOURCE:
ZANUSSI FLE1015W,THE problem i have is that once i turn on the machine and press fabric button the program lights come on and the start/pause button light flashes i press the start/pause button a sound is...
Have you selected a program?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Zanussi FLE1416W Front Load Washer
Hi, I have a Zanussi Timeline 1400 front loader and after it has completed a wash, it will not do another wash for some time. If you select a program it will think about it and then say it is complete with...
Try this..
Reading Error Codes
1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up.
Jan 30, 2011 | Zanussi ZWF1450W Front Load Washer
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
I have a zanussi washer dryer zwd12270w and the lights just keep flashing and does nothing else
I would first check your line voltage to make sure its correct. Next I would try unplugging it for 10 minutes. If thats doesnt work I would then look at replacing the control board.
Jun 16, 2010 | Zanussi ZWD12270 Front Load Washer / Dryer
Unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Oct 02, 2009 | Zanussi ZJ1217 Front Load Washer
I have a zwd12270w. Seven second after pressing
The problem is with the tumble drier heating element. If you remove the top of the machine (disconnect it from the electricity supply first!) you will find a big metal oblong "bar" that runs from the front to the rear of the machine. At the rear there are 4 white wires connected to the metal "bar". Make a note of where they go and remove them. You may need pliers to get a good grip of them. Once removed, the washing machine should work just fine but obviously the tumble drier will not. This is a well known fault and it may be worth contacting Zanussi as they MUST know about it!
Jun 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi wj1054 front load
Check the water level pressure chamber for a partial blockage, this can cause all sorts of problems.
Apr 07, 2008 | Zanussi F1045W Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
551 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
