Question about HP Pavilion zd8000 Notebook
Fans Left fan never turns
    Genius:
  • 2,028 Answers
On these models, they have a primary and secondary cooling system. The left fan is the secondary, and will only turn on if the machine reaches a certain preset temperature. I really don't think that it's something to get concerned with, but if you are concerned, you can take the fan out, clean and inspect it, and make sure the connection is seated properly. If you do take it out, check to make sure that there isn't a hair wound in it. I've had many machines come through my shop that a hair had stopped the fan.
Posted on Aug 08, 2008
SOURCE:
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
Tip
Fan Clutch R&R With Confidence Using Griller....Glitter Tool
...ever found you self asking which way to turn a mechanical fan clutch's inline coupling nut to remove clutch-fan assembly (It) without mangling a thread or special wrench? Well then, consider the Griller...Glitter mnemonic system described below and never fail to be "thread-wise in the know."
If you know or can bump the starter to see which way the fan spins viewed from the radiator, then knowing any or all of the easy-to-remember devices below will let you get that clutch off, or on, with confidence. For instance, with a left thread clutch nut, the installed clutch-fan assembly will always spin right/clockwise.
Remember, you only need to remember the ones that are easy to remember.
    ·GRILR
    ·GOES RIGHT? IT LOOSENS RIGHT.
    ·If fan clutch spins right/CW, turn its nut right/CW to loosen.
    ·GRITL
    ·GOES RIGHT? IT TIGHTENS LEFT.
    ·If fan clutch spins right/CW, turn its nut left/CCW to tighten
    ·GLILL
    ·GOES LEFT? IT LOOSENS LEFT.
    ·If fan clutch spins left/CCW, turn its nut left/CCW to loosen.
    ·GLITR
    ·GOES LEFT? IT TIGHTENS RIGHT.
    ·If fan clutch spins left/CCW, turn its nut right/CW to tighten.
on Jan 12, 2015 | Vehicle Parts & Accessories
Engine cold. Start engine reading says engine hot ac off. Fans run all time.
Are the fans running on low or high ?
Circuit/System Description
The engine control module (ECM) commands the fans ON in either high speed or low speed, depending on cooling requirements. In low speed, both fans are turned ON at a reduced speed. High speed has both fans turned ON at full speed.
In low speed operation, the ECM applies ground to the coil side of the fan low relay. This energizes the coil and applies voltage directly to the left cooling fan through the switch side of the fan low relay, which is fed by the fan 1 fuse. The right fan is connected in series to the left fan through the de-energized fan control relay so that both operate at low speed.
In high speed operation, the ECM applies a ground to the coil side of the fan low relay, the fan control relay , and the fan high relay. On the fan high relay, the energized coil closes the switch side of the relay and applies voltage directly to the right cooling fan through the switch side of the relay, which is fed by the fan 2 fuse. At the same time, the ECM energizes fan control relay pulling the switch side over, providing a direct path to ground for the left cooling fan, which has voltage applied through the energized fan low relay. In high speed mode, the fans are operated as a parallel circuit with full voltage applied to each.
You should have it hooked up to a scan tool that can read engine sensor data parameters . Check for DTC'S - diagnostic trouble codes etc...
Circuit/System Verification
  1. If DTCs P0480 or P0481 are set, perform those diagnostics first.
  2. Ignition ON, verify with a scan tool that the control module is not commanding fan activation.
  3. Ignition ON, observe that the fans are not activated.
Your best bet is to take it to a ASE certified repair shop !
Jan 10, 2016 | 2009 Chevrolet Silverado 1500
2000 grand am gt over heating radiator fans not turning on
Overall Cooling fan operation is managed by the powertrain control module (PCM). Three relays control fan motor operation. In the underhood junction block, the 30A COOL FAN 1 fuse feeds power to (left) fan control relay 1; 15A COOL FAN 2 fuse feeds power to (right) fan control relay 2. The mode control relay determines whether the left fan, the right fan or both fans are turned on. If the two fuses are OK, the problem is a defective fan relay(s) or the PCM
Sep 28, 2012 | 1999 Pontiac Grand Am GT
Right fan of my 2006 passat wont turn on.
Yes you can do that, it will work great.
May 31, 2012 | Cars & Trucks
Which way does a ceiling fan need to run in winter
Usually most peopledont want drafts on them in winter so making the fan turn with the edge thats turned down then that is the leading edge
IE say you look at the blade from the bottom
next note the blades are tilted you have to determine which way your blades are mounted. The fans may all be the same or some odd ones may be out there.
say looking up at a blade thTAs 12:00 from you
if the edge thats closer to the floor is on the left the fan turns left from 12:00 or Counter-clock wise to make the air blow toward the ceiling away from you. Reverse for cooling so the air blows on you.
This makes the air move upward.
If your ckoser edge is on the opposite side the fan turns opposite..
the edge thats turned down toward you is the direction of travel for winter
In small rooms with larger fan the air may make such a quick change that it feels like it blows on you in either direction.
Jan 15, 2012 | Hunter (25417) Ceiling Fan
Refer door left open overnite. can hear it running but fridge and freezer are not cold.and it has run all day. What can I do? .
the fan that blows air from freezer to fridge is probably frozen with ice from all the moist air when door was left open turn off unit and let defrost will see screws where fan is located to help fan defrost us hair drier to free fan when free enough to turn freely turn on unit and push door switches or close door and listen for fan to go on if goes on turn off unit and and continue to defrost till fan and duct [airway ]is clear of ice than turn on and let run -if fan doesnt go on have tested may have burnt out from trying to run while frozen up repair or replace fan and recheck unit good luck
Jun 27, 2011 | Kenmore 94499 Refrigerator
MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
Fan does not work
Test fan direct, two cable from batt to fan if fan does not turn on replace. If fan turns on relay bad.
Jun 28, 2009 | 2001 Dodge Durango
Fan clutch removal
crank the engine and see wich way the fan turns and that's the way to loose it if turns to rt it looses to rt if to the left it looses to the left
May 24, 2008 | 2001 Chevrolet Blazer
HP Pavilion zd8000 Notebook Logo
206 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
