Question about Hotpoint TDC32 Electric Dryer
Drayer problem Dryer is switch on but brum is not working.
Noise problem come from condenser dryer
Posted on Dec 31, 2010
  • Hotpoint Master
  • 19,396 Answers
Check the belt, you access toi the belt by removing the back panel.
If belt is ok, then check the timer control, the motor, and the motor control unit, that is an electronic board, usually protected by an insulating box inside the appliance.
There are also a couple of circuit breakers you should check.
Entering the model number here you get the exploded view, and replacement parts.
Posted on Sep 28, 2008
Drayer runs but does not heat up what's up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
Jul 10, 2010 | Amana NED7200TW Electric Dryer
Tumble dryer not giving heat
is the drum turning?if the drum is ok sounds like the thermo fuse on the heater box failed,most of the time it's from a clogged dryer vent hose or wall vent,let me know what you find-mike
Nov 13, 2008 | Dryers
Had the same problem on a whirpool drayer. Get our multimeter and check which heat fuse is broken. Take that one out and throw it in the floor until you have conductivity again. Clean drayer vents and heater. This worked for me, good luck.
Nov 03, 2008 | LG DLE2532W Electric Dryer
Dryer not starting
Dryer needs a new motor. I changed the thermal fuse and the dryer worked for a minute then stopped without the ability to restart.
Jul 05, 2008 | Dryers
Plastic wing inside the drayer drum fell
Replace the fin if you have found that it is broken.
May 27, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Tumble dryer
Can be a few things. Start by resetting your circuit breaker. The dryer motor can run with partial power but the heating element cannot. Make sure your not set to a no heat setting. After those checks you have to get into the mchine to check your heating element and thermostats.
Apr 12, 2008 | Whirlpool LER5636P Electric Dryer
Drayer working but no heat
No heat may mean that one side of the 240 volt circuit breaker is tripped or one fuse of the 240v circuit at the fuse/breaker box is tripped. Just replace/reset the fuse or breaker which ever you have.
Dryers will have controls working but not heat if it happens to be that particular side of the 240v circuit that tripped or fuse burned.
Jan 30, 2008 | Dryers
Draye heat work but not dry
check your exhaust vent hose inside and outside your hose you should have alot of air coming from the dryer to outside this is where Id start
Dec 30, 2007 | Maytag HYG2460AWW Gas Dryer
Tumble dryer
If you here motor running, you have a broken belt. Give brand and model and I can help you change it.
Nov 21, 2007 | Dryers
Hotpoint TDC32 Electric Dryer Logo
76 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
