Question about Kenmore 22422 Top Load Washer
Washer virbrates but is level
Washer vibrates so bad the floor of the apartment shakes but the washer is level, gets quite loud also
    Novelist:
    Champion:
  • 261 Answers
Ok, first check level at front, left to right should be level, then tilt the machine forward moving rear feet off the floor, dont use the console as it is fragile, grapple at the steel frame below. You should hear a sound of racheting, This is the rear feet adjusting, do this twice. Now if you dont hear this sound and the machine is new, check for a yellow plastic tab, shipping pin to remove, or you have a Cabrio or Oasis. If this dont work you will need to support the floor to stabilize the machine.
Posted on Aug 28, 2008
I moved my Kenmore 400 series washer into our new house and now it makes a loud banging noise, and vibrates real bad on the spin cycle. It shakes the dryer beside it it's so bad. If I sit on the washer it...
THERE S A THIN NOT REAL LARGE CONCRETE BLOCK INSTALLED AT THE FACTORY UNDER THE MACHINE. A STRAP MAY HAVE LOOSENED OR BROKE, AND THE BLOCK MAY BE MISSING. ANY SMALL YET HEAVY WEIGHT WILL WORK.
IT APPEARS YOUR BOOTY MAY BE ACTING AS THE COUNTER WEIGHT!...IF NOT,,CHECK THE CONDITION OF THE TRANSMISSION COUNTER WEIGHT (AT BASE OF TUB UNDERNEATH)
Nov 04, 2013 | Washing Machines
Washer has been shaking ever snice it was moved to have new floor installed.
Most likely your washer is not balanced evenly on the floor; get a level and level the washer accordingly. You can use shims to get it leveled. Also Home Depot or Lowes Home Improvement stores have something called Vibration Pads. I would take care of it before using your washer again since the shaking might cause problems to the actual washing machine.
Apr 11, 2013 | Maytag MAV7200 Top Load Washer
Washing machine is really loud when spinning (sounds like a plane taking off)and if you are sitting on couch one floor down you can feel the couch vibrate and the floor its on shakes like crazy. I was told...
no it is not normal and there so be no reasonable excuse for bad vibrations and shaking on a new machine ,if the setting up instructions and leveling procedures were carried out.
at six months it should be still under warranty so have it fixed under the warranty
Apr 23, 2017 | Maytag MHWZ400T Front Load Washer
Washer shakes bad
You probably have already checked this but since you do not say.........
Is the unit solid and level on the floor........with the leveling legs turned down as low as possible with the lock nuts tight.......?
If you put a glass of water on the dryer next to the washer, can you see the water vibrating when the washer is in spin? You may have weak floors.........Cement floor is the best floor, after that you need to check........
You do not say there is any noise, is the unit walking on the floor?
When new and installing there are shipping bolts and or straps to remove before using......
good luck,
enjoy the weather
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
4 month old washer is so loud it sounds like someone dropping a trash can to the pavement from 5 feet high
Check to make sure it's level. Number one cause of vibration is not being level. Number two cause is soft floor and what I call "Sympathetic vibration" where the floor shakes a bit and it seems like it's in time with the vibration on the washer. It then magnifies the vibration and makes it worse.
If it's level and on a solid floor, you need to get it serviced under warrenty.
Feb 22, 2010 | GE WSXH208A Front Load Washer
Washer shakes terribly in spin cycle
Does the floor or the walls shake? If they do you have to beef up the flooring under your washer, with blocks between the floor joists, piers, or sistering of the joists. If there is no shaking of the floor or walls, and your washer is solid on the ground, leveled and not rocking, then it is your washer. Lg has problems with too much vibration in their washers. Check to make sure that your lint filter/coin catcher is clean. Open the door in the bottom front, put a towel down to catch the water, Unplug the washer, and unscrew the large plastic screw that is the filter for your washer. If this has debris in it clean it out completely. Look in the hoses also, if your water drain is restricted by lint or coins or other debris, the washer has clothes in it that are wetter and heavier than they should be, and this will cause sever vibration. Good Luck, Appliance Specialists
Jan 26, 2010 | LG WM-2277HW Front Load Washer
Washer FTR630ASO Fridgedaire - inside tub is loose and loud
we've got this exact washer. we had a very similar sound/problem. it turn out to be the shock absorbers. easy replacement. under $100.
Oct 08, 2009 | Washing Machines
Our front load washer vibrates so much durning the spin cycle it actually knocks the dryer off the top of it. It will also vibrate across the floor unless 2 people are holding it down. We have tried the...
make sure that the nut on the leg is tihgtend down. check level lower on wash machine if all else fails buy shake away pads follow the install directions and see if that helps. i love my shake aways my floor doesnt vibrate any more.
Jul 09, 2009 | General Electric WSSH300G Front Load...
Matag washer Performa shakes badly on spin cycle
Ensure the washer is level by rocking it. If its level should'nt be able to move. You may have a weak floor. to checks this look to see if anything is vibrating around the washer.
Feb 10, 2009 | Maytag PAV2300 Top Load Washer
Kenmore HE2 Front Load Washer
is it level ? i had to level mine then i had a nut that come off had to put that back on on i am all set
May 22, 2008 | Kenmore 43142 Front Load Washer
Kenmore 22422 Top Load Washer Logo
64 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
