Question about GE Profile JGSP48 Gas Kitchen Range
Oven makes a poof noise when turning it on.
I go to turn the oven on and I hear a big poof sound. What could it be?
  • 943 Answers
HI thanks for your question. the poof you hear is the gas sorta igniting because of a failing bake igniter. i would replace it thanks if you need help don't hesitate. thanks.
Posted on Oct 14, 2008
Kenmore Elite range model c970-635131 stainless, oven stopped working
You have short in the wiring; you better call a professional repairman.
Feb 14, 2015 | Kenmore Kitchen Ranges
Upon turning on vaccum it starts ok, but a second later it spits out some dust dirt out and does not vaccum. We hear like a poof suction when this happens. Cleaned all the tubes around it, but thinking...
The poof suction sound you hear is most likely the suction release valve opening up because there is a clog or restriction somewhere. If you don't feel qualified it is usually a better idea to take it to a qualified repair facility.
Oct 26, 2013 | Panasonic Bagless Upright Vacuum Cleaner ...
Turn on gas oven; it lights, big poof/pop comes; then continues to light and heat properly. How do I stop it from popping? The pop is scary!! GE Spectra Gas Stove/Oven
The reason it "POOFS" is because the igniter is slightly weak and some gas enters before it gets lit,this will continue and get worse. To resolve it the igniter would need to be replaced and then as soon as the gas enters it would light it right away without collecting before it lit.
GENE
Oct 10, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool stove model #st387peyn1 oven won't heat. Broiler does work.Ignitor glows and after a while you hear a poof like it lite, but it did not.
When the igniter is getting weak, it will glow but not get hot enough to fully open the gas valve. If the gas valve opens partially a small amount of gas comes through the burner and you may smell it and eventually it may ignite with a "poof" like you describe. I suspect you just need to replace that igniter.
Jan 08, 2010 | Ovens
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Propane furnace "POOFS" several times when starting heat cycle
Sounds as the regulator is not operating correctly (possibly the control board)
Mar 12, 2009 | Dometic Rooftop RV Air Conditioner
Problem with oven ignition unit
It works...But I called to have the oven checked out. Thanks, tnf
Feb 19, 2009 | Kenmore Kitchen Ranges
Oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven/Broiler
If this is a gas unit then it could be caused by a gas/air ratio mixture problem, advise you get a qualified engineer to call, this could be potetially dangerous if you get a gas build up. Regards Engineer
Jul 23, 2007 | Dacor Preference PGR30 Gas Kitchen Range
GE Profile JGSP48 Gas Kitchen Range Logo
671 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
