Question about Infinity BU-1 Speaker
No manual I am trying to find a manual on this subwoofer to find out how to wire into my system.
  • gharmonmd Dec 13, 2008
    wires are disconnected.
    not sure how to wire it back.
    2 main wires coming out of wall are composed of 4 different wires each
    black, white, green, red.
    where do these attach?
This is a very good system. I have the manual, please email me
Posted on Sep 27, 2008
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here:
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
Apr 06, 2014 | Audio Players & Recorders
Why cant i get sound from my subwoofer? All wires and fuses r good but still no dound??
Check all of your connections and your receiver's surround
modes. Also, you may want to consult your troubleshooting
guide in your receiver's and subwoofers owner's manual.
Other than that, even though the receiver has been tested,
there might be a problem with the subwoofer output of the
receiver. You might also try different interconnects between
the sub and receiver -that could be the problem.
Has it worked in the past with this receiver and subwoofers?
Try it with just one subwoofer and see what happens. If you
still get no sound, then it might just be in your best interest
to get a new, higher quality receiver. That's what I did when
I ran out of help to get the subwoofer problem solved, and it
worked after replacing the receiver
Sep 20, 2012 | Car Audio & Video
I have the SB-HW950 subwoofer and teh SC-PT950 speakers and I just purchased a Denon Receiver to replace my DVD/ receiver player. So now I have SC-PT950 speakers playing through the Denon but for some...
Yes, the old Panasonic SC-PT950 did drive the subwoofer by its own amp, such as it was.
It's never a good idea to adapt prescribed connectors to bare speaker wire or vice versa.
Speaker Level and Line Level signals are worlds apart and equipment damage may result. Your Denon (model unknown) probably requires a POWERED SUBWOOFER, to which it would provide Line Level LFE from its Pre Out.
Read the manual where it doesn't say to convert a speaker wire to RCA.
Feb 06, 2011 | Panasonic Audio Players & Recorders
I have an ULTRA LINEAR HOME THEATRE SUBWOOFER + 5.1 SURROUND SOUND system i am having trouble connecting the subwoofer on the back of the subwoofer it has 4 sets of positives and negatives and i can't seem...
You should have received a MANUAL with the system. Although the RED/WHITE/Black wires relate to Positive or Negative connections, the power is low level audio which is not powerful or dangerous. If you plug any line into another port, it will not damage the system, so try to switch lines around until you get the system working. Naturally you need to place RED out to RED in and so forth; but what ever works is most important.
Feb 03, 2018 | Audio Players & Recorders
I have a subwoofer with standard speaker wire connection, how to I attach to a receiver with a subwoofer cable?
The Subwoofer is Likely Passive....meaning no amplifier is within the enclosure itself....the incompatible connectors mean you cannot connect the subwoofer itself to your surround sound system.
look for a Suitable stand-alone (1 Channel) Amplifer with sufficent power.....connect the RCA Imputs (subwoofer cable) to the Recievers RCA subwoofer output....then connect the amplifier's output to the the wire going into the subwoofer enclosure....if there is a plastic connector simply cut it off and strip the wires down a sufficent lenght....then secure the wires to the output of the amplifier.
if you do this make sure you know the ohm rating of the subwoofer and the minimum ohm rating of the amplifier your using.
Nov 24, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Apr 16, 2008 | JVC SP-PW100 Subwoofer
Can't get sound from the wireless subwoofer
There are 2 things you can try, first ensure that the digital transmitter is fully inserted into the slot of the main unit. Secondly do you have any other wireless devices near such as cordless phone or wireless network equipment? See page 5 of the installation manual as per this picture.......
Jul 25, 2007 | Panasonic SC-PT1050 System
290 people viewed this question
Top Infinity Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
