Ford 8N Tractor Logo
Posted on Apr 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a diagram of the brake system on an ford 8n tractor
Steve Allison
Level 3:
  • Ford Master 5,569 Answers
  • Posted on Apr 17, 2011
Steve Allison
Ford Master
Level 3:
Answers
5569
Questions
Helped
2002492
Points
16452
If it was mine, I would buy a service manual for it. You didn't mention the year but the link below will take you to the eBay listing for them:
Ford 8N manuals
2answers
What year is my ford tractor
history site .. try there for that ford tractor
http://www.tractordata.com/farm-tractors/tractor-brands/ford/ford-tractors.html
Mar 09, 2016 • Ford Garden
2answers
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
2answers
What year is an 8n Ford tractor serial # 202715?
complete list
http://ford8n.com/ford-tractor-serial-numbers.html
Ford 8N Tractors series Serial Numbers
Apr 06, 2015 • Ford Toys
What is the point gap for a 1948 8n ford tractor
The ignition point gap is 0.015" and the spark plug gap is 0.025". More specs here:
http://www.tractordata.com/farm-tractors/000/2/2/223-ford-8n-engine.html
1helpful
Diagrams_For ford 2N tractor starter
If you have not already found the info, I would suggest visiting the following website for some detailed help:
mytractorforum.com
No cost but will have to join to post questions. Likely all info can be had simply by searching the Ford "N" section. Good Luck!!
How do you adjust the brake locking levers on an 8N?
http://www.amazon.com/exec/obidos/ASIN/0872887537/tractordata-20
My 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
Is there a simple way to replace a fan belt on a Ford 8N?
there should be a coupler on the driven shaft. take out bolts and gently pry apart. this should allow enough room to work the new belt around the crank pulley
The steering column shaft in my 1954 Ford 8N tractor broke and I need info on howe to fix it.
Not sure, but if it's a 1954 model, it's not an 8N. 8N was only built thru 1952.
But sounds like you will need a new steering shaft.
www.Ford8N.com
4helpful
2answers
1950 8N FORD TRACTOR WON"T START.
Hi..my name is Keith..and i have 9 ford tractors..i have 9N's..2N's and 8N's..and i have converted one or two of them over to 12V..and i use the solonid that has only 1 side post...and thats what my original starter swich connects to and on the big terminal i have the battery wire and a 12 gauge wire that i run to the amp meter....i hope this helps..and if you have any questions..please write back
Top Ford Toys Experts
Kardoc
Paul Katynski
Paul Katynski
Are you a Ford Toy Expert? Answer questions, earn points and help others
