Question about Zebra (120181-001) Keyboard
Zebra keyboard kdu 120181-001
Can anyone advise me on how to set this up?
2 Suggested Answers
sgoswami
  • 114 Answers
SOURCE: Zebra Eltron KDU Keyboard and Zebra LP 2824 Printer
Hi try This:
You can check the below given link to setup the printer :
https://support.zebra.com/OA_HTML/csksxvm.jsp?nSetId=10431&nUsePub=NO&jttst0=6_50258,50258,-1,0,&jtfm0=_0_0_-1_-1_f_nv_&etfm1=&jfn=ZGE2B3DAC2686DD5CD387560DAB04C2B2C3984DAE43FA16DE7BEB235D32E65CBA52F0359FD363025E01FA80F2FA43076437F&oas=oKHnf1mAlzIrCIXJXDdicg..
and let me know if you have any further issues
Posted on Sep 21, 2009
Zebra GK420T Red light keep flashing
Seems its loosing calibration, try to reset to factory defult setting and it will calibrate with the labels that have at the moment. Please check settings at windows drivers (should be set up at Thermal transfere if using ribbon otherwise Direct Thermal if not using ribbon.
That issue can happen aswell if when sending a job to the printer with wrong settings, it will overrwrithe the previose settings of the printer.
you can untick the setting " use printer settings" at drivers as well.
if you need diferent driver go to www.seagulldrivers.com - this driver let you to resett printer to factury defaults. Hope it helps.Paulo.
Apr 03, 2014 | Zebra GK420t thermal transfer and thermal...
CHUNGHOP RM-88E Universal TV Remote i want fine code for my TV HITEC & my DVD KHiND KDU 801 pls help me
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Gopakumar Gopalan Google
Feb 16, 2014 | Televison & Video
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
I have an S4M that is used in a stand-alone label printing app. It connected to a KDU and receives input via RS232 connection. It has a stored label file on the printer. The problem is occasionally the...
The printer file is recorded in flash memory? The printer have EPL or ZPL firmware? Using ZBI may be a better solution, developed an application that stays in the printer memory and allows many uses.
Roberto Martinez
Sep 30, 2009 | Zebra S4M Thermal Label Printer
Ink smearing
This is a compatible ribbon/label combination as Zebra says. The only thing you can try is to turn up the darkness setting. The 5586 ribbon you are using requires a fairly high darkness setting ~ maybe around 25. If this still doesn't work then the best solution would be to use a Zebra card printer that prints right on the plastic card. These are made for exactly what you are trying to do. If you don't want to buy the printer then we can print them for you when you need them. I can give you my email if you want us to help.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
LP2824 Zebra printer software
Try downloading ZebraDesigner Pro here.
It should have a familar MS-Paint type interface. A small learning curve.
Sep 16, 2008 | Zebra Eltron LP 2824 Thermal Printer
Zebra (120181-001) Keyboard Logo
201 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
