Question about Ingram GeForce 2MX (32 MB) Graphic Card
Monitor Ingram Micro 1770 A/Mg 17" TFT-LCD
I have lost the manual for my ingram micro 1770 monitor how can I find out the best screen resolution
Hey dude i have the same monitor the best resolution is 1280X1240 @ 60HZ
hope this helps
wez
Posted on Sep 14, 2008
I have a black screen with a slow blinking green power button. I checked the connections they are good. I have another monitor that works fine with the same computer, and cable.
Please check your screen resolution the best resolution is 1024 x 768 on xp or if ur vedio card supports set it on 1260 x 768 for the display setting.
Mar 30, 2010 | Dell E173FPb 17" TFT LCD Monitor
ViewSonic Optiquest Q7b 17" LCD Monitor has a fuzzy picture
LCD monitor needs to be fed with native resolution from the PC video out, this monitor native resolution is 1280x1024 @60Hz, try that setting to see if it helps before opening up the monitor to look for failed components.
Mar 29, 2010 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
LIGHT VIEW 17" TFT MONITOR LM17SB OUT OF RANGE WHEN USING WINDOWS 7 WORKS FINE WITH VISTA
Set your resolution from "Display" which you can find in control panel. And fix the resolution at 1280 by 768.
Regards
Ashly
Feb 02, 2010 | Dell E173FPb 17" TFT LCD Monitor
Recomended resolution 1280x1024 how do i get rid of this?
on your desktop, click on the right click on the mouse. then go to properties, and screen settings. you can change the resolution from there. I would also recommend you to work on 1280x1024 as it fits best on the 17' you purchased.
Nov 18, 2009 | Samsung SyncMaster 710VT TFT LCD Monitor
Ingram Micro TFT-LCD monitor fault.. When my computer boots up the resolution is correct 1152 by 864 pixels but after a few seconds the resolution reverts back to 640x480 and I have to go in to screen...
CHECK THE DRIVERS FOR THE SYSTEM, THE DRIVERS CAN BE CORRUPTED, OR MISSING PARTS OF THE PROGRAM.
THE BATTERY ON THE MOTHERBOARD IS FAILING
MONITOR IS STARTING TO FAIL
VIDEO CARD ERRORING OR AND THE VIDEO CARD IS HAVING IRQ AND DMA CONFLICKS
TRY TO USE THE SAME IRQ IS OR ANOTHER DEVICE WANT TO USE AND IT IS RESETTING THE MONITOR EVERY TIME
ROD
Feb 21, 2009 | Ingram GeForce 2MX (32 MB) Graphic Card
Dell E173FPb 17" Resolution?
It depends what kind of machine you're using
Oct 25, 2008 | Dell E173FPb 17" TFT LCD Monitor
NEC 1770 monitor
click Menu, Menu/Tools, scroll down to Resolution Notifier and choose Off
Apr 27, 2008 | NEC MultiSync 1770NX 17" LCD Monitor
Dead LCD Monitor
Check if there is power voltage in the collector pin of the horizontal transistor. If there is voltage your power supply is good in the problem maybe is the high voltage section. but if there is no voltage i think your primary power supply circuit have a problem. Try to open the pin of the plyback connected to collector of horizontal B+ and open the computer . if the light indicator on the problem is maybe the plyback or the horinzontal section
Apr 06, 2008 | Gateway FPD2275W LCD Monitor
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Computers & Internet Logo
1,638 people viewed this question
Top Ingram Computers & Internet Experts
aftab Nawaz
aftab Nawaz
micky dee
Rahul
Rahul
Are you an Ingram Computer and Internet Expert? Answer questions, earn points and help others
