Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Light is on for heat dry but won't allow me to run a cyle or turn on
  • 4,323 Answers
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Posted on Apr 18, 2011
  • minvac Jul 04, 2012
    Both methods above set off diagnostic cycles, showing that power and all functions are operable. But after the tests ran their course, it was back to a start button that doesn't work when pressed directly. There are no blinking lights. Although I can live with running the first (longer) diagnostic cycle 3 times in a row to get a somewhat decent dish wash, are there any other solutions to fixing other than a new control panel for that one button's sake? thanks for your time
SOURCE:
Why does my whirlpool propane dryer light up, starts to heat then heating unit shuts I down, dryer keeps running, doesn't dry. Thermal fuse has continuity?
The "High limit" safety is an automatically re setting safety device.
It will reset after it cools down , I suspect the limit is bad due to short cyling from the vent tube being crunched or dirty or simply worn.
Apr 30, 2014 | Dryers
Dishwasher won't run, clean light flashing
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 06, 2011 | Maytag Dishwasher
Clean light is flashing and dishwasher won't turn
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Kenmore Dishwashers
My clean light keeps blinking and will not turn off or allow the start button to turn on.
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Oct 12, 2009 | Whirlpool Dishwashers
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
How do i reset my dishwasher when the light is flashing AND NOT WORKING
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Aug 24, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
DISHWASHER BLINKS 7 TIMES ON CLEAN ONLY RUN ON CANCEL
-high temp wash
-heated dry
-high temp wash
-heated dry
Please rate this solution as Fixya and revret for further assistance.
Thanks
Rylee
Jul 03, 2009 | Kenmore Dishwashers
Clean light flashes
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore elete dishwasher flashing light clean
-high temp wash
-heated dry
-high temp wash
-heated dry
Dec 06, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Whirlpool gu2400 dishwasher
-high temp wash
-heated dry
-high temp wash
-heated dry
Dec 05, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
1,376 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
