Question about Kenmore 73952 Gas Dryer
Kenmore Frigidare Front load dryer 417.93042203
I am tryng to convert this unit back from LP to natural gas...have the jet kit..but gas valve and jets appear to be on the front side of the dryer....trying to figure out how the clips work so I dont destroy them...
How do I remove the front cover for access to the jets I need to replace?
Kerry
Thank you!
[email protected]
The front panel clips usually hold by friction. Just pull gently on the upper corners and it should hinge down.
Posted on Sep 25, 2008
6ya staff
SOURCE:
Convert my kitchen aid gas dryer from lp gas to natural gas
You will need a re-jet to do this, where you can buy the kit I have no idea.
Oct 10, 2018 | Kitchen Ranges
What is the conversion kit I need to convert this fryer from natural to LP?
the conversion is new jets for the unit
however as the new jets require a different setting of the air deflector to maintain the correct air /gas ratio , I strongly suggest that you get in an accredited gas fitter to do the job
Nov 04, 2015 | Kitchen Appliances - Others
WANT TO CONVERT LP BACK TO NATURAL GAS. MODEL KDSS907SSS05 SERIAL NO. D34417432. NEED NATURAL GAS ORIFICE KIT.
have this done by a gas fitter as it is not just a matter of different jets but also an adjustment of the air shroud around those jets to obtain a clear flame at the flame rings (hobs)
Jul 09, 2015 | KitchenAid Kitchen Ranges
Have Kenmore elite dryer. How do you get into it to convert from LP to natural gas?
most require a kit to change from 1 type gas to the other . they have to come in thru the back someplace
Feb 09, 2015 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore grill 146.23766310
Here is the owner's manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/1212186L.pdf
In it, it states, "Use grill, as purchased, only with LP (propane) gas and the regulator/valve assembly supplied"
Oct 30, 2013 | Grilling
Hi im a plumber/gas fitter who has been asked if i can convert a wildcat 410 (a2) ser 1983 from lpg to ng which is currently in use at a crash repair spray booth is this possible?
Yes look up the gas valve part # and find the LP kit for that model number. It will come with new pilot orifice, new burner orifices and the springs to replace inside the gas valve. Remember that natural gas is .08"wc and LP is a heavier gas it needs to be set at 11"wc .You need a manometer to check the pressure before you light it again .Did you know that propane provides more energy per unit volume than natural gas. Heat is measured in BTUs, or British Thermal Units. Propane provides about 2500 BTUs for the same volume of natural gas that only gives 1000 BTUs.
Nov 22, 2010 | Heating & Cooling
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
I have Natural gas and am moving where it will be hooked up to lP instead. What do I need to convert to LP from Natural Gas
you will need an L.P. conversion kit. the kit contains a small spring, a new brass orifice and a new brass cap that fits on the gas valve. some kits are minus the spring. you will most likely have to remove the burner to put the new orifice in. any appliance repair store will be able to order you the kit. have model and serial number handy. good luck with your move into the country.
Oct 20, 2009 | Kenmore Elite HE4 Electric Dryer
Want to convert from LP to Natural Gas
Typically, the only thing required is changing any and all jets since energy content and pressure are different. The only source for these is probably the manufacturer; check their website.
May 20, 2009 | Grilling
Jenn Air 740-0141 LP to NG Conversion
If the grill can be converted, it's usually a matter of providing a source for the natural gas and then changing the gas jets for the burner(s) and possibly a regulator, depending on your model. Some grills may require changing the gas burner valves themselves. Kits are usually available from a dealer unless the unit is old.
The natural gas jet will be slightly larger than the propane jet because natural gas doesn't have as high a heating value as propane.
If you do this, check your new conversion for any leaks using a soap solution in a spray bottle.
Just be aware that the grill may not get as hot with natural gas and cooking could take a little longer, but should still work just fine.
Your natural gas line should typically be about 1/2" unless it's huge or is over 50-60 feet away from the grill location. If so, use a 3/4" line. Piping material and methods are usually governed by your local building codes.
Mar 17, 2009 | Thermos Stainless Steel Gas Grill
Kenmore 73952 Gas Dryer Logo
276 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
