Question about Canon Office Equipment & Supplies
Canon Imageclass D860 - I have a System Error E000 code on the LDC display. No paper jam or other problems evident. Disconnected power for 10 minutes and that didn't help. For this error code I am to call service but there is no one in Vermont and I would have to ship out of State w/no indication of problem or cost to repair. I have two machines - one nearly brand new - both with same error code. Hate to just dump them. Any suggestions?
  • 148 Answers
This is a reprint from another tech, he was right on with this...
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used until the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no response means the fixing assy didn't even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arrow buttons to scroll to #4 printer reset press set. press the appropriate arrow key under the YES to clear the error. unplug the copier and reboot. At this time normal function should return if not and it resets a E00 the you can assume either the fixing assy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to research the problem to avoid spending money on excess parts
Hope that helps...
Lbcoaster
Posted on Aug 09, 2008
System error E000
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Please let me know if you need any further help
Apr 06, 2008 | Canon imageCLASS D860 All-In-One Laser...
System error E000
  • Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer"
  • Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
  • Then press "Set" again, and the display will ask you "Yes" or "No"
  • Press the "Left" arrow for "Yes", then press "Set".
  • Now, unplug the power cord and wait 5 seconds and plug back in
That should clear the error. If it doesn't, get a new fuser.
Feb 29, 2008 | Canon imageCLASS D860 All-In-One Laser...
Error Msg E000
E000 is a fixing unit failure...either the thermistor or fixing lamp failed. Not sure about individual part replacement, most likely needs entire unit replaced....then reset the code.
Aug 03, 2009 | Canon Office Equipment & Supplies
Canon Imageclas D860 Error Code E000 Have tried unplugging the unit and then restarting to no avail
E000
The error history indicates any of the following error codes 4 times: E001, E002, E003.
Action 1) Clear the error.
Execute '#4 PRINTER RESET" under '#7 PRINTER' in service mode to clear the
error.; then, turn back on the power.
Apr 14, 2009 | Canon imageCLASS D860 All-In-One Laser...
System error E000
Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser.
Feb 14, 2008 | Canon imageCLASS D860 All-In-One Laser...
System error E000
Press the "additional Function" key
Press the # key
Press F3 key until "Printer" shows up.
Press "OK" key
Press F3 key until "Printer Reset shows up
Press "OK" key
Press the * (star) key
Turn printer OFF then back ON
Jul 07, 2008 | Canon imageCLASS 2300 All-In-One Laser...
System error E000
check the settings for the alarm and also the software.
Jun 10, 2008 | Canon imageCLASS D860 All-In-One Laser...
System error E000
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Apr 14, 2008 | Canon imageCLASS D860 All-In-One Laser...
Error Message - System Error E000
Does a page come out? just blank? How old is your cartridge, did you pull the tape out? Need more info to help.
Aug 28, 2007 | Canon imageCLASS D860 All-In-One Laser...
215 people viewed this question
old marine
old marine
