Question about Acer Aspire 5500 5570-2609 Laptop
Acer 4520 light going dim
On my laptop my screen light goes really dim when I plug it up to the adapter. when I unplug the laptop the screen light becomes lighter! what's happening to my computer light.
    Scholar:
  • 39 Answers
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Posted on Aug 11, 2008
Fn and f8 which is the arrow up button when it is plugged in will brighten the screen, press fn and f7 which is the arrow down button when unplugged to save power
or fn and which ever keys have the sun face on it,it kind of looks like a star figure
Posted on May 09, 2012
  • dbelcher630
    dbelcher630 May 09, 2012
    fn and f8 which is the arrow up button when it is plugged in will brighten the screen, press fn and f7 which is the arrow down button when unplugged to save power
The backlight on my screen went out
2 things could be happening here..The good: the screen has just been dimmed and needs to be adjustedThe bad: The back lights are failing and need the screen needs to be replaced.
Nov 17, 2011 | Acer Aspire 4520-5582 Notebook
I have a acer 4520 laptop and it will not turn on. I purchased a new adapter and it will not turn on still. when I plug the adapter in the battery light will not turn on
The problem is with the plug inside of your laptop. If the light on the adapter is on (if there is one), but the light on the laptop is off, then the internal wiring is either damaged or loose. You can try to open the case and examine the wiring (only if you are a DIY type). Otherwise, take it to a computer store and have them take a look.
May 16, 2011 | Acer Aspire 4520 Series Laptop Charger...
I have an Acer Aspire 4520 and the batter will not stay charged and it keeps shutting down even though I have it plugged in. Please help.
Hi there, please perform power drain first. Take out the battery and unplug the power adapter. Press and hold the power button for 30secs. Put the battery back in, plug in the power adapater then turn on the computer. If same issue will occur then you need to replace your battery.
May 16, 2010 | Computers & Internet
Pluged aspire 4520 in at night. next morning, no lights no power. nothing
if the unit will power one with ac adapter plugged in then you have a bad battery. check to see if you dc jack on the lap top lights up when you plug in the AC. if it does not light up then your dc jack or ac adapter is bad.
Jan 27, 2010 | Acer Aspire 4520-5582 Notebook
Hello..my acer aspire 4520 does not on if i press the power button..if i plug the power adapter the battery light blink continiously..can u please tell me wat is the problem..
just conncet the power cord and leave the laptop fro 10 -15 minutes and then try to on if it on well otherwise remove the battery and direclty switch on the laptop on main power.
Jan 20, 2010 | Acer Aspire 4520-5582 Notebook
Laptop ACER Aspire 4920 Screen goes dim.
there is a configuration of each one of the three plans of energy, and there you can change the time the screen is on when plugged or unplugged, the brightnes, and some stuff more like the wireless. you have to go to "energy option", or something like that... mine is in spanish. and then under each option is the configuration. good luck!!
F.R.C.
Jul 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Screen flickers on Acer Aspire A150 Netbook
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 08, 2009 | Acer Aspire One A150-1006 Notebook
I have an Acer Aspire 4520 that will not charge when the laptop is powered up. it. The video goes bright and then dim - back and forth - like you are plugging in the power supply and then unplugging it....
I've seen something like this before, but I can tell you it's not just an Acer trait. It's not often that this happens, but one of the ways you can tell, if you have access to one, is by using a voltmeter to check the voltage of the power adapter tip. The proper reading for most laptop adapters should be around the 19V mark. If you are unsure, take your computer to a local repair shop, describe the symptoms and ask to have the power adapter tested, to see if that's the fault. If the power adapter is reading proper voltages, then chances are good it may be the power coupling or power board inside the laptop, in which case you would have to get it serviced by an authorized service center. If you are currently under warranty either through your place of purchase, or with Acer directly, have them service it, and it should be covered by warranty. If not, repairs can be costly for this kind of issue. Power coupling replacements can usually run you around $250 USD for parts/labour. If it's the power board or motherboard, then costs can jump to $400-500 USD for parts/labour, if not more.
May 06, 2009 | Acer Aspire 4520-5582 Notebook
Acer aspire 4520 won't boot
Try this.
Unplug both AC ADAPTER and remove battery.
Press and hold POWER BUTTON for 30 seconds.
Plug in AC ADAPTER.
Turn on.
After log in, place battery in.
Apr 26, 2009 | Acer Aspire 4520-5950 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
445 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
