The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows:
To install the cable that connects a front panel audio solution to the front panel audio header,
follow these steps:
To restore back panel operations
follow these steps:
1. Remove the front panel audio cable.
2. Install a jumper on pins 5-6 (rear R channel).
3. Install a jumper on pins 9-10 (rear L channel).
4. Install a jumper on pins 1-2 (mic).
5. Replace the cover.
