Question about Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio Ap3800 service manual
Hello i saw that u have the service manual can u pls mail it to me if u have it in electronical version. My mail is alexu_1@yahoo.com
Thanks
Best Regards
  • 97 Answers
You can download the manuals here :
michelsplace.fr
Posted on Sep 08, 2011
  • 37 Answers
I will have to know in witch country you live , cause if i give it to the wrong people in the wrong country i can get into big trouble , cause these manuals are not to be distributed .some secrets of the trade
Posted on Aug 14, 2008
How do i connect ap3800 to computer
Depending on how your network is set up, you have a couple options. If you have no network, then you can not print unless the machine is equip with a parallel print connection.
Mar 13, 2011 | Ricoh Aficio AP3800C Laser Printer
WHAT DOES THE SC 38 MEAN ?? WHAT FAULT DOES THIS SERVICE CODE REFER TO?? I HAVE A LANIER 2138 COLOUR LASER PRINTER, (SAME AS RICOF AP3800 SERIES)
SC is for "Service Call". The error may be caused by a defect or an irritation of internal sensors.
Ricoh recommends to physically switch off the printer, wait for a few minutes and power on again. (Irritation by change in surrounding temperature)
If you recently replaced any movable parts inside, remove it again and reseat, many parts inside are checked by sensors for proper seating.
If this does not help, you need to call Ricoh customer service.
Feb 09, 2010 | Ricoh Aficio 3800CMF Laser Printer
I need the service manual for the Aficio 220
hello there here is several links that will help you out ok
best regards michael
  1. RICOH AFICIO 220 Service Manual RICOH AFICIO 220 - It's a complete service manual, and it's in PDF format. ... i got my service manual for philips vr685-02. Thanks a lot for my very clear and ...www.user-manuals.com/service-manual-RICOH-AFICIO220.html - 73k - Cached
  2. Ricoh Service Manuals - Copier Service Manuals Ricoh Service Manual/Parts catalog CD's for FT, NC, Fax, FX, Afico, AP, MLP, SLP, ... Ricoh Service Manual/Parts catalog CD's for FT, NC, Fax, FX, Aficio, AP, MLP, ...www.knowthesource.com/index.php?cPath=26 - 57k - Cached
  3. AFICIO 220 RICOH AFICIO 220 Owner's Manual ... for delivery information. Model: AFICIO 220. Type: Owner's Manual. Delivery: ... Manual received - Many thanks for an excellent service. Alain Fagan - 2006-04-11 ...www.manuals-in-pdf.com/55709-p-11284.html - 65k - Cached
Sep 14, 2009 | Office Equipment & Supplies
HI I am trying to connect my printer via a router
You need to plug your comuter into one of the LAN Port and the Copier into another LAN port your Modem into toyr WAN port. Then you will need the IP of the router it should com along with the router Info and either be 192.168.000.1 or 192.168.0.1. add an ip spec range Isusualle use 192.168.000.120 this goes into your copier under network protacals in user tools. under the same area setup sub net mask 255.255.255.0 if you have already installed you Ricoh AP3800 Driver place the ip 192.168.000.120 again the 3rd set of numbers either .000 or .001 depending on your router. SO under start menu go to either printer and faxes or control panel right click on printer icon for ricoh AP3800 go to properties select the ports tab, Click add Port select Standared TCP ip Clickm the new port. Click next Add your IP adress for the Copier here. Click next Next window will have Generic network card so press NEXT and then Finished Close printer ports window and then click apply. This should get you printing
May 16, 2009 | Ricoh Aficio AP3800C Laser Printer
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh ap3800 error code sc261
Hi there the following is taken from the service manual. Thanks J
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
Jan 14, 2008 | Ricoh Aficio AP3800C Laser Printer
Any one know where i can download a free service manual. Yes i am skint!
hello my name is ghacem of iran want know abut cod for to light or darken ricoh copier thank you
my e mail (ghacem_moradi@yahoo.com)
Dec 05, 2007 | Ricoh Aficio AP3800C Laser Printer
Error Message sc376
I am pretty sure Sc376 is your Magenta not Cyan. try replacing your magenta developer unit and your magenta drum unit. If you buy them from a dealer you will have to buy all the colors not just magenta. Try Ebay first and search for supplies for your model.
Oct 17, 2007 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
390 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
