Question about Star Logic 17" LCD Monitor
Star logic 19" lcd monitor
The on "green light" button just keeps flashing and making a clicking noise but the monitor will not come on. Please Help
  • elainasip Aug 09, 2008
    I have the same problem. I was thinking of purchasing a new ac cord. But when I unplug it from the actual monitor it stops blinking. Is there something wrong with the monitor. I really do not want to purchase a new one. HELP
  • Star Logic Master
  • 5,568 Answers
This is most often caused by a serious failure and the power supply is protecting itself and you from fire by cycling the AC off and on.
Posted on Aug 08, 2008
I have a Star Logic LCD monitor. Recently I have been having a problem powering the monitor on. Sometimes when I press the power button or bring it out of hibernation, the screen remains black and the...
First place to check will be the DC filter caps in the power supply section. See example of failed monitors due to bad caps here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Sep 10, 2010 | Star Logic 17" LCD Monitor
I have a Planar 1910(Black) LCD from a friend. It first had a problem where it would show no display but the power LED would flash green to orange. I fixed the problem by reseting it. Now that the display...
It has white screen becuase it may not be getting the 5vdc from the logic board to the T-CON board or the board has blown fuse.
Please see http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Also look to see if power supply/logic bd had any bad caps also.
Aug 14, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
Monitor is blank and the power light keeps flashing green.
When you switch on both Poota and Monitor, is there visual startup flashes or startup information showing on screen.
Make sure the monitor connect to rear of poota is located and firmly in place and properly screwed in?
Nov 12, 2009 | Dell E196FP 19" LCD Monitor
19" star logic MJ9BBK suddenly changed color
First check the connections to make sure they are tight,next go to desktop settings and make sure the external monitor has the same color configuration.
Sep 03, 2009 | Star Logic 17" LCD Monitor
Flashing green light
http://www.xerox-displays.com/drivers.html
This is the link to the xerox install info. This should fix the problem. If it does not please list the CPU OS and video card you have. Before connecting the LCD monitor make sure in your display properties are set to a refresh rate of 60 hertz. You can set refresh rate by going to the control panel in windows and display settings properties.
Jan 16, 2009 | Xerox XG-91D 19" LCD Monitor
POWERED ON MONITOR, FLASHES ON, THEN GOES BLACK, MAKES NOISE
This is general LCD monitor advice. I don't know your specific model. Your problem, however, is very common on many different monitors.
In 90% of cases, the problem is one or more failed electrolytic capacitors on the power supply board. They are a simple matter to replace, but require desoldering the old ones and soldering in new ones, as well as general electrical/electronic safety practices.
If what I've just said already makes sense to you, then you're probably qualified - go ahead and replace them. If I'm talking greek, then go find an electronics nerd - some goofy looking guy wielding a soldering gun should do.
Oct 31, 2008 | Dell E196FP 19" LCD Monitor
19 inch star logic monitor
bad vga board however you can open it up and see if the capactors are blown replacing them may solve this problem however when an LCD monitor goes white typically it is the microchip that has gone bad so I sell the monitor for parts and buy a new one.
Aug 18, 2008 | Star Logic 17" LCD Monitor
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck Housecall101@aol.com
Jul 24, 2008 | Star Logic 17" LCD Monitor
BLANK MONITOR
the signal stage of your monitor is likely to have a problem, if the cpu is working fine then troubleshoot the signal stage of your monitor or visit a local technician
Dec 06, 2007 | Star Logic 17" LCD Monitor
Power button flashing green on and off. No Picture
What type of monitor do you have? I need to no if the power supply or cord plugs directly into the LCD Monitor? These questions are important! Please answer these questions, I will be able to give you an answer!
Nov 25, 2007 | Acer AL1916W 19" LCD Monitor
Star Logic 17" LCD Monitor Logo
145 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
