Question about Whirlpool Dishwashers
Normal light blinks - Whirlpool Dishwashers
  • 4,323 Answers
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Posted on Apr 18, 2011
SOURCE:
Whirlpool dishwasher model# gu2200xtss3 normal light flasing all the time turning power off does not help in a few minutes back on flashing
The light blinking is an error code--usually it will blink a certain number of times, pause, then blink another sequence(ex. 4 times, then 3 times)in a binary error code. There is a chart in the service manual to decipher the code(s) and locate the issue. It could be anything from a heater circuit failure to the drain pump being jammed. Try to see how many times the light blinks, and which ones blink--there could be, on the first part of the sequence, normal light, then, 2 or 3 lights blink-- I need to know which ones are lit. Thanks! You can try to look up the light combinations on the net with a search for your model number and error codes.
Oct 12, 2015 | Whirlpool Dishwashers
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Daniel
May 19, 2011 | Maytag Dishwasher
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
May 10, 2009 | GE Dishwashers
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
"normal cycle" light keeps blinking
The blinking button indicates the button is bad. The button console will have to be replaced.
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Dishwashers Logo
931 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
