Connecting a freeview box
I've had a new digital aerial fitted, i purchased a freeview box, the aerial
man connected it but when i tried to watch a dvd he'd put the scart lead
from my dvd player into the freeview box, i maneged to sort that, but the
problem now is i'm unable to record tv programs + watch them from the vcr
player, the freeview box has 2 scart sockets at the back and an aerial in and patch lead out to the video, as a result of this i tried swapping leads about but got the same result, got picture through freeview box but nothing else, contacted the aerial company but they said it would be £50 for someone to come out to me, i refuse to pay that, i know it's not the answer but i have now disconnected the freeview box, please can you help me to overcome this problem, i have a dvd player in av2, vcr av1, do i need to buy a multi scart connector? for something that's suppose to be so easy, it's just giving me problems, can you help?
    Sergeant:
  • 291 Answers
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Posted on Aug 16, 2008
SOURCE:
I can't record digital tv on the dvd recorder coupled with a new philips tv with built in digital
You need a freeview box to connect to the scart INPUT of the DVD recorder. The Freeview box has to have a programmable timer built in. Connect your aerial to the freeview box, the aerial output then goes into the TV. You program the DVD to the times you want to record each program, but always the input is the SCart. You the program the Freeview box to change to the right program at the beginning of the program you want to record.
Jun 27, 2011 | Mico DVDR311
I have a Hikona TC 1400 TV and after the digital switch over now need a digibox to watch freeview etc. I have purchased a digibox followed the installation instructions but the tv is all blue with no...
With a digital set top box, you do not need an antenna for your TV. You need to switch the TV to whatever input you have connected the TV to. Usually the set top box is connected to the TV by an HDMI cable. Take a look at what input on your TV the cable connects to, and then set the TV to that input. It should then work fine.
Jan 03, 2018 | Televison & Video
Can you tell me how to tune in a channel when ppreparing to use a freeview box on a onyx sw 1536 ld
Unless you've got an "expensive" Freeview box that modulates its output on to the RF (Aerial) connector then you can't. Most Freeview boxes have 2 aerial connectors - 1 IN from the Aerial itself and 1 OUT to connect to the TV - BUT this is ONLY a PASS-THROUGH connection. This means that the digital Freeview signal which is decoded from the aerial signals is NOT output on the OUT connector and sent down the co-axial cable to your TV. Only the "old" ANALOGUE (not Freeview NON DIGITAL) comes down that co-ax. What you should do is connect the Freeview box to your TV with a SCART cable via the SCART connectors on both. You need to select the AV input on the TV using the remote.
Even if you do have an "expensive" box that does modulate the digital decoded programmes and output these of the RF OUT connector, you should still use a SCART cable as the picture produced will be far better
Hope this helps
Jul 06, 2010 | Televison & Video
How do i set up atv without inbuilt digital a seperate digital box and a video recorder?the tv digital tuner and video all have scart leads.Should the aerial cable go to the video or digital box?
Aerial to digi box first then video then tv (not strictly necessary)
Depending on what you want to do with the vcr and the digi minimum scart connection is
digi to video - video to tv
Nov 08, 2009 | Computers & Internet
Freeview - No transmitter found
The signal from the communal aerial might be weak, since other people are using it, or it is experiencing interference with a power cable or something.
Try a signal booster from **** Smith or Harvey Norman, RadioShack, Tandy, Walmart etc ( I assume you are Australian - Freeview :) )
OR
Get your own aerial, if you don't live in a concrete shoebox....
Oct 12, 2009 | Televison & Video
We have purchased a Phillips freeview box but am unable to get a signal !! We have the tv arial plugged into the back of the freeview box into the tv and the scart connected from freeview to tv. Do we...
Yes
If the Freeview box is not connected to the main aerial socket, you cannot get a signal.
Also, you will need a digital aerial, if you don't already have one.
Jun 09, 2008 | Philips Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Televison & Video Logo
187 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
