Question about Brother MFC 210C All-In-One InkJet Printer
I replaced the cartridge ( magenta) and it says "no cartridge" when there is
I took out each cartridge and replaced them and it says when I close the lid "no cartridge" I know its there, I bought it and it doesn't work. what do I do. I unplugged the machine for a couple minutes, then repluged it and it still says "no cartridge"
  • Anonymous Aug 15, 2008
    We have just replaced the magenta cartridge as well and we have the same problem "no cartridge". We have a Brother MFC-210C
Power the machine down and pull all of the cartridges. Get some alcohol and a long cotton or foam swabs with a wooden stick, not a paper one. If you look down in the ink compartment to right side of where the cartridges fit you will see that there are some thin clear plastic pieces that cover the cartridge level sensors. Give those a cleaning. A fair amount of ink came off on mine. Plug all the cartridges back in and power back up...
Posted on Aug 19, 2008
I have just had the same problem but have just now fixed it...I took out all of the cartridges and then put them in from back to front, starting with the black and working my way to the cyan. It worked and the printer started to clean immediately.
Posted on Aug 15, 2008
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
We have replaced the magenta imaging unit and no magenta is coming through can you help
Ensure you removed the cellotape from the cartridge. pull out and put back cartridge.
Jul 29, 2008 | Minolta Office Equipment & Supplies
Genuine brother ink cartridge not detected by printer on DCP J315W printer
This is a common occurrence for these machines. They can get confused when cartridges are changed before they read as empty.
To correct this.
1) Unplug the printer from both the Power and Computer and remove all cartridges closing the cartridge access panel.
2) Plug the printer into the Power only and turn on. The machine will complain about no cartridges, this is fine.
3) Open Ink access panel and insert the first cartridge (Black is most common and close the panel.
4) The machine will complain about the missing cartridges. Open the panel and insert the second cartridge in the sequence and close the panel again.
5) Repeat the process for the third and fourth cartridge.
6) Once all cartridges have been installed the printer will ask if you have replaced the cartridges. Say no to the Black, Cyan and Yellow but yes to the Magenta and it will display the correct readings.
If this process fails to read the cartridge still then there is something wrong with the sensor inside the machine which probably means new machine.
Aug 15, 2014 | Brother DCP Office Equipment & Supplies
MFC-J430W will not recognize any new magenta cartridge!
When installing the cartridges, it is important that you insert them from left to right with the black cartridge first and the magenta cartridge last. The reason for this is because the magenta cartridge has a clip on top of it that goes into the cartridge door sensor. The clip needs to push the sensor in so the printer is able to function with the cartridge door open. If you insert the magenta cartridge first, the printer will think the cartridge door is closed and you will get a error message for the other missing cartridges.
May 29, 2013 | Brother Office Equipment & Supplies
The light for the magenta cartridge on my iP3500 printer goes off
The cartridge, as well as all ink jet cartridges has a chip inside that tells it how much ink is in the cartridge. Your cartridge is LYING, except it prevents you from printing without all cartridges working. ( same for my 6 color epson ). You need to replace the cartridge. I get my cartridges at a yahoo store called Inks4less. They have good quality for cheap.
There was a study done, analizing the amount of inks left in inkjet cartridges when they indicated empty, and the range was 7% to 25% ink still left.
Oct 03, 2009 | Canon PIXMA iP3500 Printer
Magenta cartridge in hp4600 leaking
it is usually the cartridge that is the problem. the 4600 is famous or infamous for this problem.
Sep 01, 2009 | HP LaserJet 4600 Printer
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
Replacing Cartridges on the HP Color Laserjet CM1312nfi
Yes, you will replace the whole cartridge. Open the front door and pull out the cartridge drawer. Grab the handle for the magenta and pull it straight up. There should be directions in the box.
Jan 20, 2009 | HP (Q6473A) Print Cartridge for Color...
Printer says I have duplicate Magenta cartridges when I don't?
I think it's the chips on the cartridge - the colour that it thinks it's duplicating! I took it off the black (duplicated) and put it on the magenta and it thought it had duplicate magenta cartridges!!
Jan 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Brother DCP 130C not printing magenta and yellow
after replacing the ink cartridges it took several cleans to come good. I have no idea how to "manually" clean the heads. So I told the printer to do it many (about 7) times. It eventually worked
Aug 11, 2007 | Brother DCP 130C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
49 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
