Question about Canon PowerShot SD600 Digital Camera
Lens retracts with difficulty
The lens retracts with a jerky halting motion when I turn the camera off or zoom out from telephoto. I haven't dropped the camera, gotten it wet or anything. What to do?
  • 3 Answers
1. Do you have a camera case?
2. Or do you not?
The dust fibers from the case might have gotten into the cracks of the lens causing it to jam. So everytime it retracts, it jams. That's what i'm guessing. My old camera got jammed from sand grains on the beach.
- Take a thin strip of paper, and insert it in the cracks of the lens and circle around the lens and find any dust or anything. The paper slip should come out a bit dirty if that's the issue.
- Gently nudge the lens around, until you hear a click. The lens might have jerked into another position from the inside.
Posted on Aug 10, 2008
Why does the focusing ring on the efs 55-250mm not retract all the way when you turn the camera off
I doesn't return to it's closed position when the camera is turned off. You have to do it manually . Turn the zoom ring to the 55 position then turn the front focus ring fully to the left.
Apr 27, 2014 | Canon Ef-s 55-250mm F/4.0-5.6 Is Telephoto...
I have a Canon Zoom EF-S 18-55mm lens and I'm not sure if it got damaged when I accidentally dipped my camera into the ocean. I haven't turned the camera one, but when i look through the lens...
Sorry, but salt water immersion is effectively just as destructive to your camera and lens as if they had been crushed or burnt. If the body and lens were immersed in seawater then they are complete write-offs as they will be completely beyond economic repair.
Aug 08, 2011 | Canon EFS telephoto zoom lens 55 mm 50 mm
The camera was dropped on the lens and zoom won't retract
HI there, the camera lens gear is damaged from internal. So you must changed that. Other wise it gives you lot of trouble. Thanks.
Mar 12, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
My daughters zoom lens is stuck open and just makes noise when you turn it on..what should I do?
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 18, 2009 | Olympus Stylus 840 Digital Camera
Purchase Zoom Lenses
Canon currently makes super Telephoto lenses from 300mm to 800mm and a number of zoom Telephoto lenses from 28-300 to 100-400. You can also special order a 1200mm lens from Canon at a cost of $99k! (There are only about 20 such lenses made so far.)
You can also get a 1.4 or 2x teleconverter to further increase the power of a telephoto lens. However, the cameras are unable to auto-focus when the minimum f-stop exceeds f/8, which can happen when you use one (or both) of the teleconverters on these longer lenses, so you have to manually focus the lens.
You can also get telephoto lenses from other manufacturers such as Tamron and Sigma that are built to work with Canon cameras. However, the Canon lenses are generally regarded as the best quality.
Dec 21, 2008 | Nikon D70s Digital Camera
Adding a telephoto lens
Try zooming in. That usually gets rid of the "vignetting" you are experinecing.
May 02, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Telephoto lens for digital camera
It will not work because it is the wrong thread size. Here is info on the Olympus TCON-17 lens for the 5050: TCON-17 (1.7X) Telephoto Conversion Lens Extend the capabilities of your digital camera with the TCON-17 Telephoto Converter lens. This telephoto lens will increase the magnification of your subject by 1.7x when your camera lens is set to the telephoto position. This will help you bring in the subject when you can't get closer, for example, shooting sports or concerts. Please see below for additional items required to attach this lens to your camera. The following models require the CLA-1 and 43-55mm Step-Up Ring: C-2000/2020/2040/3000/3020/3030/3040/4000/4040/5050 Zoom ....... The video lens is too small (diameter). If you found one with a 43mm thread and put it on the 5050, you would experience severe vignetting (clipping of the corners of the photo).
Sep 05, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
Canon PowerShot SD600 Digital Camera Logo
128 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
