Question about LG WM-2277HW Front Load Washer
Front load wash smells moldy
We love our LG front loader, however it smells and the gray rubber ring looks stained with mold. Also, water stays trapped under the ring. I clean it after each use and leave the door open so that it dries out. I've run clorox through the system and sprayed every product known to man on inside the machine, but this only mask the odor for a short while. It's driving me crazy and making my laundry room smell bad. Any ideas?
  • Anonymous Aug 09, 2008
    I haven't noticed any mold in the machine but I do have a distinct mildew smell and it makes my clothes smell very unpleasant. Now my soap dispenser drawer is stuck closed. I am looking for a different washer, LG has been no help. Good luck in figuring out the mold problem, I will repost if I find a solution.
  • epblj Aug 11, 2008
    Same problem here! I have also tried bleach and leaving the door open to air out but doesn't help too much. I am disappointed in the LG washer and will not buy another. Too many problems! Am currently waiting on a tech to find out why it's not draining (error code oe). It's not the drain hoses! Have had other issues too. Disappointed!
  • 706 Answers
A few ideas to try but understand that these will not solve your problem 100%,.. To begin with. make sure you are using HE type detergent and use ONLY a few drops per load..any more than that will just end up damaging the front door hinge hardware and you will have to replace that... As for the mold problem.. that has plagued this type of washer for a while.. to my knowledge.. there is no known cure but you can buy Afresh tablets from ( home depot carries them) .. and run them thru a wash cycle about once a month ( more if necessary) .. they do seem to help a little,...I too have the same washer and have been most disappointed by the degree of problems it has had.. Also.. keeping the door open and wiping the gray gasket ( including the area that where water exits the washer..) may help a little too,...
Hope that helps...
Posted on Aug 17, 2008
I AM ALWAYS GETTING MOLD INSIDE THE LG FRONT LOADER. THE RUBBER SEAL IS ALWAYS MOLDY
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. If the growth is very high then try and leave the door open for 4-5 hours and let it dry and then spray the bleach+water (3:1) mixture on the seal. Let it dry for another 2-3 hours. You may need to change the seal in case of extreme growth of mold. Hope this helps...
Daniel
Aug 30, 2010 | LG WM-2077C Front Load Washer
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
While I was ill our daughter in law over loaded the washer and now there is a moldy mildewy smell. I have cleaned the drum by running a load of bleach water with no clothes, but the smell seems to be...
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Mar 04, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Water sitting and mold growing in the rubber gasket ring around the opening for the door
affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 09, 2009 | LG WM-2277HW Front Load Washer
Mold on gasket of LG WM2016CW
the biggest problem with front loaders is that the seal is so good you end up with a moisture issue all the time (which will cause mold). My suggestion to you is always leave the door open when not in use and also try not to leave clothes in the machine after a cycle is over. leaving the door open and a few good cleanings will solve your problem
Aug 22, 2009 | LG WM-2277HW Front Load Washer
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM - awful smell while washer is running
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
They offer some great products on smellywasher.com. Also, if you keep the dispenser door open about a quarter of the way when not using the machine, this tends to help as well.
Oct 21, 2008 | Washing Machines
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
LG WM-2277HW Front Load Washer Logo
160 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
