Loaded software onto PC. Can not get the TX to hotsync.
I had this proble with my blackberrt 8100 whenever ni put my battery in my phone a battery with a red line i shown in the lcd i don't know what it is can you please help me with my problem
Posted on Oct 08, 2008
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Can not get fi fi on my tx even though I have been getting it for a year
what is the problem you are facing
pelas explain it clearly
Sep 16, 2008 | Computers & Internet
Unable to connect with desktop through usb cable
Jan 24, 2011
1 post
Oct 19, 2004
Mar 16, 2004
Dec 18, 2002
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
What do I need to use keyboard #3169WW to my palm TX? And how do I hook it up? Thanks for any information.
The "Getting Started" booklet essentially says the following, but I'm restating it just in case.
If you lack this booklet and/or the "User Guide," you can download them from the following:
http://kb.palm.com/wps/portal/kb/na/keyboards/palmuniversalwirelesskeyboard/unlocked/home/page_en.html
The keyboard comes with an installation disk that you run on your PC or Mac.  Do so.
It will set up a program called keyboard.prc to be installed on the T'X at your next HotSync.
After the HotSync, unfold the keyboard, add batteries, and place the T'X onto it.
Run "keyboard" on your T'X and it should connect.  You'll be able to set preferences and shortcuts.
Dec 17, 2010 | Palm TX Handheld
Using the desktop, is there anyway to move(either to the memory card or the PC) or delete files on a Palm TX. I apparently used to much of the devices memory and now I can't ge to the home screen(it...
If you're able to hotsync, then yes. In the desktop, delete notes or other items (Does the TX have voice memos? Those would be a quick way to free up a lot of space!)
Perform a hotsync, and your Palm should then have some free memory.
If you're not able to hotsync, then nothing you do in the Desktop will have any effect on the Palm.
But, I'm skeptical that this is the real problem. It sounds more like memory corruption, and a hard reset is going to be the real fix.
Sep 14, 2009 | Palm TX Handheld
When you do a hard reset:
Yes I would remove first
Aug 07, 2009 | Palm TX Handheld
Error (sys 0505)(0,841)
I entered "Sys 0505" in the Search box on the main Palm support site and got a bunch of hits, one of which is a Palm Knowledge Base article which would suggest that the error might be related to a file (these hits suggest a backlight file though the last four digits of the error are different) which might have gotten onto your TX if you upgraded from an older Palm.
http://tinyurl.com/2vwqq4
http://tinyurl.com/2rq73o
Hope this helps. If it's not the backlight file, it could be some other relic system file from an older Palm. You might have to try Hard Resetting your TX, renaming the Backup folder on your desktop, then Hotsyncing your regular PIM data back and reinstalling your third-party apps one at a time. This routine is the customary way to try to troubleshoot a software problem, which is prolly what you have. Now, if you have never had a prior Palm handheld and there's no way it could be a legacy system file from a prior device...I dunno...I would still suggest going the Hard Reset route, renaming your backup folder to backupold, Hotsyncing your data, make sure it's all working, then reinstall your 3rd party applications.
Jul 30, 2009 | Palm TX Handheld
I am unable to HotSync and cannot load HotSync manager
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
Software download to handheld
You must have Palm Desktop installed on your pc. You must have a serial cable from your pc to your handheld. You must have hotsync running on your taskbar. You must download the software to the Palm Desktop and then hotsync your Palm with the pc. You may not be starting the safe hotsync in the start menu before pressing the hotsync icon on your Palm. If it's not that, your pc may not be recognising your Palm device or you may not have your serial cable securely hooked up, or you may be trying to download software that's not compatible with your device. You also have to reset your device after installing most software. Make sure you have enough memory to hold the software.
Apr 02, 2008 | Palm TX Handheld
HotSync Outlook 2003 with Tungsten E
I tried all the suggestions that were offered and gave up. But then out of pure craziness I loaded the treo 600 CD that came with my Treo 600 out of curiosity. It loaded and the MS Office 2003 conduits loaded nicely and the problem appears to be solved for now. So I tested and it the Tungsten E Hotsync's feature all appear to be okay. I'm not sure if this is the best solution but it solved a very frustrating problem. The version of Hotsync that loaded is 4.1.0. Hope this helps.
Sep 11, 2005 | Palm Tungsten E Handheld
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
