Question about Goodmans Televison & Video
Will your Digital Vidio Disc Recorder With HDMI work with dm technol LV 19xTM id tv dvd If it will not work is there an adapter or similar i could buy so i can use the machine
    Master:
  • 555 Answers
What model DVD Recorder are you asking about?
Posted on Aug 08, 2008
    Brigadier General:
  • 3,614 Answers
You can use a composite rca cable jack.
How can I make a NEC Plasma Monitor that was given to me work like a TV that has AUDIO?
If it has no internal sound, then you obviously can't make it function like a TV aside from the picture right? It does have inputs whether HDMI or standard Cable wiring to see TV from a cable box?
You'd need to have RCA cables coming from the cable box (Audio out - white wire I'd figure) going into a stereo near the monitor that has a VIDEO button on it where the white RCA cable is plugged into the Audio In jack.
A stereo receiver or even old sort of stereo with a Video or Auxillary sort of jack with button to activate that jack will allow for surround sound from the stereo coming from the cable box in sync with the video of the TV.
Feb 08, 2015 | NEC PlasmaSync PX-42VP5A 42 in. HDTV-Ready...
Not receiving a TV signal through the DVD recorder and cannot record programs or watch TV through the DVD recorder
Firstly you must have a good connection from your antennae to the dvd recorder, secondly a good connection between recorder and tv
via scart lead or hdmi. Check these out before you do anything else.
Mar 21, 2014 | Panasonic Dmr-XW380 Dvd Recorder
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
Vcr tape . does not record to dvd-r disc Using hdmi cable from TV to recorder.
It is a HDMI OUT on the DVD/VCR Recorder.
You can only record to a DVD/VCR from the External DVD/VCR Input (Connected to a Freeview, Cable or Satellite Box etc) or from one to the other.
Jun 09, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
DVD recorder will not pick up digital channels from TV
Our DVD recorder DMR-EH57 is recording but not able to show its video
recording to the LCD what is the problem.
Nov 08, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
How to hook up a dvd recorder with HTS6500/37?
Suddenly had this problem. My Phillips is hooked up to TV and to Cable Box. When I inserted a DVD it would return a "no disc" but it would read and play CDs. After a call to Phillips...who said that they had no idea what was going on and I should take it in for service...it was 4 months out of warranty. Repair company said it was not worth the repair costs ($200) so I should try cleaning the lens with a lens cleaning disc. I bought a Maxell. It has a set of little brushes on the bottom of the disc. I inserted it and played track 2 for 20 seconds as instructed and voila! It began reading the DVDs again. I was only out the $10 for the disc cleaner. If you have this problem, try the disc cleaner first as it might be the fix.
Oct 03, 2008 | Philips HTS-6500/37 System
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
DVD RECORDER INDICATES "NO DISC "WHEN DISC IS INSERTED IN DVD RECORDER does not show any thing on tv when used with hdmi cable
Does this problem only occur when a HDMI cable is inserted (No Disc problem)? If so then the hardware is probably faulty. Try returning it for a new player.
Dec 21, 2007 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Goodmans Televison & Video Experts
Raj Patel
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
