Question about LG KU990 Viewty
'Crackling' Noises Most of the times when I plug my Viewty into a power source it starts to make cracking noises straight away. This also continues for about 20-30 minuets after taking the phone off the power source. What should I do? Thanks, Andy
This happened to my phone not too long after i purchased it.
I had to have the curcit board replaced.
Posted on Aug 23, 2008
My TH-15A starts making VERY loud crackling noises after a few minutes of being turned on. It does not matter if an XLR cable is plugged in or not, and the volume control does not change the volume of the...
buy a canister cold spray and spray on some active components if the noise begins You have a thermical failure in a component on the board can be faltering resistorcircuits or resoldering some active components.
May 08, 2016 | Mackie Tapco Th15a Thump Active...
Marantz 4220 Power Switch Dear experts Some time ago when unit switched on cracking noises in speakers started. But now exept ligting up no sound is comming just little when volume turned up.What could...
The Amplifier was failing and that's why you were getting the crackling noise.
Most receivers have an Auto Protect that shuts the system down and goes into Protect mode at the first signs of failure or overheating, usually indication by 'Protect' on the display.
I'm presuming from your post that you never got any indication that the unit was shutting down to protect itself and has just failed, so I'm presuming that this facility isn't fitted on this model.
Depending on you Technical ability it could be an easy repair (replacing the complete PCB or some PCB components). Your only other solution is a visit to a service engineer.
Jun 04, 2011 | Marantz Audio Players & Recorders
Rattling, crackling type noise just started and is constant when microwave is running.
A couple of months ago my microwave started making crackling, rattling and grinding sounds everytime i used it and i thought it was going to break down. It turned out one of my children must have spillled or overflowed something with a clear liquid because the micro did not look dirty but there was a crunchy substance under the wheels of the turntable. Once i cleaned this up totally the noises all went away.
Jan 19, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Crackling noises while tv is on
We had a TV that did that once and the TV repair man said it was a CRT leak which is flamable. So you may want to be careful with it.
May 27, 2010 | RCA Scenium D34W20 34" TV
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Wavey color lines at bottom of picture. Crackling noises coming from back bad picture
Howdy;
The "crackling noises" from the back is causing the picture to distort. 1) Either locate source of "noise" and correct or 2) Call a Service Company and get corrected. I would recommend that you DO NOT USE TV until this corrected. It may cause a fire inside your TV.
Good Luck, Big Irish.
Nov 22, 2009 | Televison & Video
Sherwood Rx4050r and right speaker has crackling noises.
Ahh, that channel is blown. Its not 100% blown. This has happened to my freind before, and from my long knowlage in audio, the channel is blown, and is not fixable. If you REALLY are attached to it, you could probably bring it to a shop that fixes receivers, but best bet is to let it go
Oct 12, 2009 | Sherwood Audio Players & Recorders
Small black device within RCA RP5420
That black disc is the "backup" alarm if you lose power.... The battery then takes over and "buzzs" throught that little speaker too wake you... even tho there is no power... Mine buzzes too... cut that little speaker outta there.!
Robert
Oct 23, 2007 | RCA RP5420 Clock Radio
Losing volume on channels
I am afraid not. That crackling is a component in one of the solid state amp circuits starting to fail. These are all soldered into the printed circuit board. This could be a difficult repair to find an intermittant component. Depending on how old the unit is and how much it cost will factor in on if you have it repaired or not. Rule of thumb is that if the unit is two to three years old and cost less the 200 to 300 bucks you should not invest more then 100 to 150 bucks into it. Good Luck
Mar 14, 2007 | Sony STR-DB840 Receiver
LG KU990 Viewty Logo
35 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
